Wire gauge in PSU (newbie)
Hi Speek
As long as the run from the PSU to the amp is short (~10cm), then you should be OK with 0.75mm^2 wire. I used 32/0.2 = 1mm^2 wire in mine.
On a slightly different note, does anyone know of a comaprison chart between AWG / SWG / conductor area?
See ya,
Tim.
wire guages
here's a chart from the most recent issue of QEX:
