no current mirror, current mirror, cascoded current mirror, bjt or jfet VAS? - Page 3 - diyAudio
Old 25th April 2008, 06:48 PM   #21
maxpou is offline maxpou  Canada
maxpou's Avatar
And now at 100Khz
Old 25th April 2008, 08:07 PM   #22
peufeu is offline peufeu  France
Tiny bit of overshoot but otherwise looks good.
And the sound ?
Anyway, inserting a 100R in the output is always a smart move, just in case you get a short at the output (easy with RCAs), to avoid smoking the JFETs... it will also protect against oscillations.
If you use it to drive headphones (but the JFETs seem a bit wimpy for that) you must add a resistor since headphone jacks short for a brief time on connection.
Old 25th April 2008, 10:37 PM   #23
maxpou's Avatar
Hi Peufeu,
i don't know how it sound because i take all mesurement on my breadboard. thank you Maxpou
Old 25th April 2008, 11:08 PM   #24
aparatusonitus's Avatar
Hi maxpou,
Pulse response looks good, no ringing at all, try some small compensation capacitor over local feedback resistors to take care of overshoot.
Non é mai abbastanza...
Old 26th April 2008, 09:30 AM   #25
Onvinyl's Avatar
Hi Maxou,
You could as well try without the output followers. The overshoot will most probably vanish, the stability (into capacitive loads) is amazing. I would probe the output while it is connected to the following amp and check the sound both with complimentary output follower and without.
Nice work, keep it going!
Rüdiger
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog
Old 28th April 2008, 06:24 PM   #26
maxpou's Avatar
Hi Guys,
here the pic without the output stage with 3.9K//300pf. thank you! Maxpou
Old 28th April 2008, 06:50 PM   #27
Onvinyl's Avatar
At what freq?
Rüdiger
Edit:
if it's 10kHz, it's not good. I have a very simple version of this with 170/74 in the front and BC550/BC560 as VAS, set for 6dB of gain, and the square is fine up to several tens of khz!
Old 28th April 2008, 09:30 PM   #28
maxpou's Avatar
Hi Rüdiger,
sorry i forgot the frequency: 100Khz. Thank you! Maxpou
Old 30th May 2008, 09:08 PM   #29
Onvinyl's Avatar
Hi Maxpou,
you could swap the bases of Q14 and Q18 to the corresponding FET drains. increases (ol-) gain and decreases distortion.
Rüdiger
Old 30th May 2008, 10:14 PM   #30
Originally posted by maxpou
Hi Maxpou,
in my opinion
please f*** 2nd, 3rd, 4th harmonics
but beware of this 15kHz peak!
Better use OLG,
true
regards, Pawel
Current Mirror Discussion AKSA Solid State 348 24th March 2017 09:21 AM
Current mirror for the aleph? 3nity Pass Labs 11 8th August 2013 07:23 AM
High current mirror ? forr Solid State 23 25th June 2009 08:31 AM
Current Mirror: The V-mirror rtarbell Solid State 1 19th November 2008 02:27 PM
Current mirror abzug Solid State 7 1st January 2008 07:03 PM
Copyright ©1999-2017 diyAudio
