Old 20th April 2008, 01:39 PM   #1
kirk57 is offline kirk57  United States
Default Modifications for Superphon Revelation Dual Mono
I have 2 superphon revelation dual mono pre-amps, circa 1986,
which have served quite well for all these years. Serial numbers
are 01270 DM and 01291 DM. I'd like to know of any suggestions about modifications of this preamp, given it is now
over 20 years old. BTW I have not had any problems with the pots or mute switch on either unit.
I did replace what I believe is C10,11,12 and 13 with 100uF 50v
blackgates. I use it mostly for playing lps, so anything to enhance the phono section would be great.
I also have two DM 200s....any suggestions for those would also be appreciated. or maybe that should be another thread..
Maybe if I get lucky the guy who designed these will answer :-)
Kirk
Old 20th April 2008, 04:07 PM   #2
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
If you could post a schematic it would be much easier for us to give you advices
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com
Old 27th April 2008, 01:08 PM   #3
Stan-
Is it OK with you if I post the schematic? I think it's OK since this unit has not been in production for over twenty years, but I'd feel better if I knew it was OK with you....
Kirk
Old 1st May 2008, 01:44 PM   #4
Here is the schematic:
Any suggestions would be appreciated!
Kirk
Superphon Revelation MK II PreAmp yeoldestereo Solid State 60 28th March 2012 02:32 PM
Superphon Revelation pre amp greeen Solid State 2 18th April 2009 09:30 PM
FS: Superphon Revelation...needs a fix JoshK Swap Meet 7 10th February 2009 01:46 AM
MM cartridge body modifications for mono? vanmeter Analogue Source 4 12th September 2007 01:01 AM
Dual Mono - Anti Mono Power Supplies pmkap Everything Else 3 16th February 2002 05:10 AM
Page generated in 0.09175 seconds (77.42% PHP - 22.58% MySQL) with 10 queries
