Does anyone have, or know where I can get, a scematic diagram/service manual for the above? The 2SA1216 in the LH Channel has failed(Base/Collector short-circuit). Having 'cold checked' and visually inspected other components, I replaced both output transistors(The NPN one is a 2SC2922) only to find that the centre rail, which should be 0v is about +25v w.r.t. ground. The relay and driver transistors check out OK 'cold'
Any suggestions as to what else needs replacing??
#2 |
also for short circuit and if this circuit includes clamp diodes check them also ....also check rail fuses to see if they are ok
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#3 |
The two 4amp fuses in the transformer secondary circuit had blown, due to the original fault. Replacement 4A(T) Fuses OK after amp was powered for a couple of minutes whislt checking it. The driver Transistors check OK 'cold', don't know about clamp diodes, though I will check for them, but a schematic would still be helpful, if one can be obtained. There are a number of green LEDs on the main amp PCB. Not certain what they are there for, but they all illuminate.
#4 |
I'm pretty sure there are more threads about this amp with input from the designer. At least two people in those threads offer a schematic.
The search button can be very useful sometimes.
Martin + |
#5 |
I had done a search before posting my request, but, unless I've missed something(quite possible!!) there are no threads on this forum relating specifically to the A3i Amplifier, which include a schematic diagram. I will have another look, however, in case something has appeared since this morning(UK Time)
#6 |
Hi there dont know if you fixed amp or not but also check the big resistors for open circuit and when the output blows normally takes the little black trim pot with it also ,,and replace all leds (green) these set up the current in amp.make sure they stand above board get hot...
if you strip it for parts keep them for years as soon as you get rid you will want them ..................... |
#7 |
I had actually fixed that amplifier sometime in April/May last year, having obtained a circuit diagram for it. In the end, from memory, I replaced at least one faulty LED(They, as you no doubt know, don't fail too often), and some other parts. After setting it up, I test ran it for several hours a day, then it went back to it's owner. So far as I know it's working fine to this day. Your post may help others having problems with Cambridge Amplifiers, though. |
| looking for a pre-amp schematic | steamPunk | Tubes / Valves | 3 | 3rd August 2008 01:49 PM |
| DBX 500 schematic | d3imlay | Solid State | 0 | 2nd August 2008 05:12 PM |
| F3 schematic | kenev | Pass Labs | 2 | 24th January 2008 03:24 PM |
| Help with this schematic? | imix500 | Parts | 4 | 11th August 2004 10:08 AM |
| Page generated in 0.08053 seconds (78.81% PHP - 21.19% MySQL) with 10 queries |
