Old 18th April 2008, 10:33 PM   #1
TimS is offline TimS  New Zealand
Default The New Hyper Balanced Amplifier
This is an amp design that I have been working on for a while. I am now at a point where, I think, it is good enough to post on diyAudio.com It ticks most of my requirements for a good audio power amplifier: Wide Open Loop Bandwidth (>20kHz) Low-ish Distortion No more than 2 Stage design Stable while clipping What Attributes I like about this amplifier: Wide Bandwidth Medium Open Loop gain Very Stable Each Quadrant has its own feedback loop, If any pair of quadrant clips and the feed back loop goes open then there are 2 more feedback loops to keep control. Good common mode rejection. I hope you all like it. If there is any critiques or improvement let me know Cheers Tim
File Type: png hyperbalanced amp with cascode diff input.png (37.1 KB, 743 views)
Old 19th April 2008, 01:20 AM   #2
One amp to get a BTL output, cool.
Question, can you drive this amp with a regular unbalanced input source and still get the BTL output?
Old 19th April 2008, 02:11 AM   #3
CBS240 is offline CBS240  United States
CBS240's Avatar
Doubtful, since the feedback loops are a voltage divider with the input signal. The drive signals for M67/M68 will be unequal in magnitude. I have built a circuit that will convert SE signals into BL, with gain and DC control. Maybe a bit complex but it works very well. Also, there is these if you have vendetta against discrete circuits.
All the trouble I've ever been in started out as fun......
Old 19th April 2008, 05:15 AM   #4
It will be fine. All that will happen is 1/2 of the cycle will clip earlier than the other.
Cheers
Tim
Old 20th April 2008, 07:00 PM   #5
Default Frequency and Phase Response Curves
Frequency and Phase Response Curves, from the simulation
File Type: png hyperbalanced amp - frequency responce.png (26.8 KB, 303 views)
Old 20th April 2008, 07:54 PM   #6
KSTR is offline KSTR  Germany
KSTR's Avatar
Tim, may I suggest to use more data points on these (say 200/decade)? Although not very likely here, the sim could have missed a high Q-resonance just before the roll-off.
Your plots are with plain resisitive load, I guess, no series L//R and no zobels. What happens if you hook a load cap (stepping it from 1nF to 10uF, 1-3-10 steps)?
For testing simmed stability I like to use a step voltage source of 100mV or so, with 10ns rise time, putting it into various places into the circuit (not only at the input) and then look at any overshoot/ringing, also at various places, not only the output (sometimes one can invoke hefty CM ringing which doen't show up at the output).
More elobarate stuff is the Tian method of plotting open-loog gain bode plots, which also provides much insight wrt small signal transfer function.
- Klaus
Old 21st April 2008, 01:02 AM   #7
Hi KSTR
Thanks for your help.
You are right there is a resonant peak at about 1MHz and this is highlighted when I simulated the AC response with a 1uF across the output (and no series resistance).
I tried a quick brute force fix, by increasing my 3pF compensation capacitors to 30pF, which does stabilise the amplifier into 1uF but it reduces the open loop bandwidth and so increases the higher order harmonics in the distortion.
I suspect the culprit for this resonance is the input cascode, I think it is 2 mosfets too many. I have had similar performance without them but I had to use lower value feedback resistors to get the same closed loop bandwidth. Maybe I will try JFETs instead of the input mosfets and get rid of the cascode.
I ran out of time, this morning, to try anything else so I will look at the design again in the evening.
Cheers
Tim
Balanced amplifier alternatives Elvee Solid State 7 1st August 2007 09:19 AM
Balanced amplifier trend? LBHajdu Pass Labs 12 29th September 2005 02:32 AM
Have you ever built this balanced amplifier aht Solid State 2 15th November 2004 06:55 AM
boss hyper fuzz honsten Instruments and Amps 0 19th May 2004 09:36 PM
Page generated in 0.09963 seconds (76.28% PHP - 23.72% MySQL) with 11 queries
