Can anyone suggest a wiring diagram to connect two 110v trannys to get 220/240v ?
#2 |
What is it you need to do?
Jut connecting two 110v secondaries in series will get you in the area for many purposes, but that may not be enough if you need a full240v from 110v input - the step-up configuration will tend to exaggerate the apparant voltage drop under load. |
#3 |
The 110v are the primary's.
#4 |
OK, but is it 240v input, and 240v output you want, or what combination..?
If you mean 110v primary:110v secondary transformers - you could connect two transformers with both primaries in series and two secondaries in series, and apply 240v to get a 240v:240V composite transformer, but it's not a good idea on the whole. |
#5 |
What I am trying to achieve is 240v input by using two 110v transformers. the ac output is immaterial at present.
#6 |
Then just connect the two primary -side windings in series. You can leave al teh secondaries uncommitted.
Don't expect this to be very useful. Use a minimum-value mains fuse etc. Assuming good matching, these transformers will be seeing 120VAc each, but it's not guaranteed: if wildly different in VA capacity, the smallermay be exposed to even higher voltages . Even more seriously, if they are wound for 60Hz (US etc) mains, the cores will be under-sized for use in the UK anywhere near rated capacity, and I would expect them likely to hum badly. HTH! |
#7 |
the problem IMO is that having transformers in series they must supply the same power otherwise you will get an inbalance between the transformers and the output voltages will vary.
I suggest you use one with the correct primary or use a 230/110 autotransformer to drive the 110 devices in parallel. |
| Changing Voltage Req from 110V, 60Hz to 220-240V, 50Hz? | pingpong | Pass Labs | 3 | 13th June 2010 03:09 AM |
| Pass X1 Pre:Voltage change from 110V to 220-240V | rc5al | Pass Labs | 0 | 24th May 2009 08:45 AM |
| How easy is it to convert from 110V AC to 240V AC? | spikeyfaz | Analog Line Level | 19 | 26th December 2007 07:14 PM |
| power conversion US to UK [110v to 240v] | make | Power Supplies | 2 | 12th February 2007 07:53 AM |
| 240V- 110V Marantz | geddam | Power Supplies | 0 | 8th May 2005 11:04 PM |
| Page generated in 0.08892 seconds (72.98% PHP - 27.02% MySQL) with 10 queries |
