Standard SR-157SW
Standard SR-157SW
Old 15th March 2009, 09:09 PM   #21
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default 2SB77 and 2N408 can be used too.
Also AC127 and AC128... those are small...maximum 1 watt of dissipation, for low level audio stages.
Can be used as drivers when powered using 12 Volts... into the output, they can produce 500 miliwatts if attached to heatsinks using thermal compound.
Germanium is very sensitive to heat... gain is low, power dissipation use to be small and thermal drift is enormous...also they use to be noisy.
Carlos
Old 15th March 2009, 09:37 PM   #22
mjf is offline mjf  Austria
hello.
found an old schematic (hifi-nostalgia).............
they are all similar,like today............
greetings..............
Old 15th March 2009, 10:33 PM   #23
hello.
output cap (470uf) is small (it cuts off the bass).........i would try to use 1000uf(minimum) with 8 ohm speakers and 2200uf with 4 ohm......
Old 15th March 2009, 10:48 PM   #24
and c16(100nf) at the base of q4 is very small too...........
Old 15th March 2009, 11:09 PM   #25
Default I have assembled both during the seventies
Was a brazilian Kit.... the union of Phillips, Ibrape and Miniwatt resulted into a big company that started to sell audio kits.
Ibrape was "Brazilian Industry of components"
And Miniwatt was a division from the Philips factory that made electronic tubes (valves)
and those schematics you show were used...i have assembled both down the seventies... sounded fine for those days standards.
Inspecting the circuit i found some differences...the output used here was matched AD161 and AD162... drivers was AC187 and AC188 and supply was 24 volts DC.
regards,
Carlos
Old 11th August 2017, 04:21 PM   #26
BobtheBuilderMLG is offline BobtheBuilderMLG  United States
BobtheBuilderMLG's Avatar
Hey, everyone I know this is way old but I was hoping for some help. I recently got one of these and unfortunately it has been modified with silicone transistors and the circuit does seem to have been changed aswell. I would love to get this unit back to stock. Any help would be greatly appreciated.
Old 12th August 2017, 11:46 PM   #27
Anyone?
Standard SR-157SWHide this!Advertise here!
output standard? dead rat Analog Line Level 4 9th October 2008 05:54 PM
Non-standard rackmount Nixie Parts 5 13th October 2006 01:29 AM
Use standard 317 or 317L? Christer Parts 16 7th July 2006 06:41 PM
Non-Standard Connectors Steve Eddy Parts 16 3rd October 2002 10:06 AM
