Leach amp transistors - diyAudio
Old 8th March 2003, 10:54 AM   #1
supernet's Avatar
Question Leach amp transistors
I am building Leach amp and I want to use TO 247 devices and I do not know which to choose : 2SC5200 2SA1943 from Toshiba or
MJL 1302A MJL 3281A from Onsemi. Transistors from Toshiba are cheaper, but I am concerned about power rating 150 W instead of ONsemi 200 watts of disipation.
Since Leach amp produces near 300 W / 4 ohm I am not sure which to use.
Please help!!
Old 8th March 2003, 08:53 PM   #2
Jeff R is offline Jeff R  United States
Either would be fine from a power dissipation standpoint. The power rating of the amplifier is the power into the load, not the power dissipated by the transistor. Plus, it is pretty unlikely you will ever be operating at maximum power. Still, why skimp on a couple of dollars?
TO-247's are not as good as TO-3's in shedding power to the heatsink, so use care in how you mount the transistors to the heatsink.
Old 8th March 2003, 09:16 PM   #3
stokessd's Avatar
This may or may not be an issue, but there are a TON of surplus TO-3 heat sinks out there. I got the original spec Leach transistors in TO-3 cans. I am probably the only one on the planet who likes TO-3's. They have very low thermal resistance in the case, and swap out effortlessly. A solid stae tube socket of sorts...
Sheldon
Old 10th March 2003, 03:37 AM   #4
djk is offline djk
djk's Avatar
In addition to the plastic package having a higher thermal mounting resistance, the metal package is also rated at 25% more watts at room temperature. What is often overlooked is the maximum junction temperature for metal is much higher. All things concidered, I use twice as many plastic as I do metal for a given power.
Old 10th March 2003, 05:41 PM   #5
supernet's Avatar
Thanks for reply.
What do you think, is it any electrical or quality difference between those two types (MJL1302 vs SA1943) ?
Supernet
Old 10th March 2003, 08:56 PM   #6
Send a message via AIM to BeanZ
What about the ON Semi MJL21193/ 94 pair?
BeanZ
Old 11th March 2003, 08:20 PM   #7
supernet's Avatar
Hard to get in my country.
Old 12th March 2003, 06:43 AM   #8
swede is offline swede  Switzerland
swede's Avatar
What country?
//magnus
Old 12th March 2003, 02:59 PM   #9
supernet's Avatar
Slowenia!!
Old 12th March 2003, 03:03 PM   #10
swede's Avatar
Send me a sixpack of beer, and I'll send you some MJL21193/94 (plastic or to3, your choice).
//magnus
My Leach Amp Clone (LEACH 150) panson_hk Solid State 32 22nd May 2014 11:25 AM
High Current Leach/leach super amp bowdown Solid State 41 2nd March 2011 02:15 PM
Leach output transistors pooge Solid State 5 14th January 2005 09:26 AM
Leach - mixing Power Transistors Arco Solid State 7 15th August 2003 07:12 PM
Replacement transistors for leach amp Bosium Solid State 12 13th June 2003 09:07 AM
Copyright 1999-2017 diyAudio
