hi, how to make Overload and Short Circuit Protection for amp?
thank you. |
#2 |
Check this paper! (See attachement!)
#3 |
Andy L. Francis, good article!
I prefer not use emitter resistors, if possible. In this time I place collector resistors and sensor with SOA approximation. After follows trigger on two transistors and switch, which shutdowns driver. |
#4 |
Anyone has more design notes for OP protection circuits?
I'm interested. Thanks. |
#5 |
Anybody?
#6 |
This is sample of SOA protection. This variant don't affect on sound of amplifier
#7 |
I'd be interested in getting any information possible on protection circuits (short-circuit protection & over-current protection) for QUASI output stage. Thanks.
Sam |
#8 |
Kostya-M, how can we use this? Can you help us describe us how it works?
Thank you in advance. |
#9 |
If current throw output transistor (VT15/16) is high, voltage on sense resistor 0.1 Ohm opens transistor VT18 or VT22. Circuit with resistors 50-59 and zenners varies open current as to limit power dissipation on output transistors. VT19-21 - trigger. It opens VT17 and VT23. Its must switch off driver’s cascade.
#10 |
Kostya-M, thank you for your answer.
I cannot understand how it works. I am confused about how it will sense the overload and how i will set it for specific transistors. I guess that this is a sample, as you wrote, do you have a schematic more specific? I think that this could be help me more. Thank you. |
| short circuit protection | roofingboom | Solid State | 109 | 1st May 2012 02:28 PM |
| Short circuit protection | MiiB | Solid State | 0 | 16th May 2006 06:48 AM |
| Overload protection circuit. Does it work correctly? | Fritzell | Solid State | 16 | 19th September 2005 02:19 PM |
| short-circuit protection in mosfet's amp...?? | csl113 | Solid State | 8 | 31st January 2005 06:10 PM |
| Short circuit protection | JBL | Solid State | 20 | 5th August 2002 07:27 AM |
| Page generated in 0.10457 seconds (77.36% PHP - 22.64% MySQL) with 11 queries |
