Dunlap -Clarke Dreadnaught 500 Power/ amp.
Old 7th March 2003, 10:27 PM   #1
Raymond is offline Raymond  United Kingdom
Send a message via Yahoo to Raymond
Question Dunlap -Clarke Dreadnaught 500 Power/ amp.
Hello to all,
I'm a new member and this is my first thread...
Does anyone have any information on the Dunlap-Clarke Dreadnaught 500 power/amp? The only info I have on this model is that it was made in the U.S.A. circa 78, it was imported to England by Exposure Electronics before they made their own amplification. I believe it delivers about 600watts R.M.S. per channel into a 2ohm load and that's all the info I have on the unit.
Can anyone enlighten me?
Raymond.
Old 9th March 2003, 12:27 AM   #2
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Well, it's been about 28 years, but I had occasion to peer inside one, and it seemed to be a conventional push-pull AB follower with a really big output stage. It recall that it had MJ802 and MH4502's (I could be mistaken) which were the biggest BJT's you could get back then and some serious fans.
I subsequently had a nice conversation with the designer (Ron Dunlap?) at a show. A very smart, nice guy, who by then had quit the business for other pursuits.
Probably not even Jam has schematics for this, but it was a simple enough circuit that you could reverse engineer it or otherwise service it if you had to.
Old 9th March 2003, 03:38 AM   #3
jam is offline jam  United States
jam's Avatar
You are right Mr.Pass, I dont.
Jam
Old 9th March 2003, 06:22 AM   #4
djk is offline djk
R.I.P
djk's Avatar
Single ended diff inputs with an active current source for the VAS (like a Pass A40). 2N6030/5630 outputs parallel connected in the D250, series/parallel connected for the larger amps (like a Dynaco ST416). I think I still have the schema for the preamp and D250 power amp.
Old 9th March 2003, 11:59 AM   #5
Dj BASS AMP is offline Dj BASS AMP
Account Disabled
i need to a circuit of 600W RMS AMP to 2 - 1 Ohm speakers...
Old 9th March 2003, 12:06 PM   #6
Thank you Nelson,DJK and Jam for your positive response.
I bought the amplifier here in England together with the matching pre-amp, the power amp sounds a lot better than some of the well respected designs..... I use it with a Naim 42.5 pre/amp at the moment and it sounds very detailed and informative. I think that the power caps will need replacing as they are the original ones. I don't use the matching pre/amp as it sounds very constricted. My speakers are Linn Isobariks so I opted for an amplifier that will deliver a fairly large output into a low impedance load "I think the Linn's drop to 2ohm.
Thanks again.
Regards to you all.
Raymond.
Old 9th March 2003, 05:31 PM   #7
The one and only
Great! Please post it if you can find it.
Old 9th March 2003, 09:01 PM   #8
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Default Re: Dunlap -Clarke Dreadnaught 500 Power/ amp.
We had one of those thru the shop when i worked hifi. Not sure which one. Nice amp, but became unobtainable.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 9th March 2003, 09:22 PM   #9
Default Re: Re: Dunlap -Clarke Dreadnaught 500 Power/ amp.
dave
Thanks for the info Dave. It does sound nice, although it's quite old and there are better power amps out there it's the best power amp I have heard for quite a while and it cost me peanuts.
Old 9th March 2003, 09:52 PM   #10
frugal-phile(tm)
planet10's Avatar
Default Re: Re: Re: Dunlap -Clarke Dreadnaught 500 Power/ amp.
The Frugal-phile(tm) in me loves those peanuts. Did you ever have a NAIM power amp in your system?
At the time we had the DC we were also selling NAIM 160s & 250s. The NAIMs were a bit more refined, but didn't have the balls of the DC.
dave
Dunlap -Clarke Dreadnaught 500 Power/ amp.Hide this!Advertise here!
Dunlap Clarke Dreadnaught 1000 amp Richard Swann Solid State 33 1st April 2010 12:50 AM
Dunlap- Clarke Dreadnought 500 Power Amp Raymond Solid State 1 25th November 2008 10:12 AM
Arthur C. Clarke died abzug The Lounge 5 2nd April 2008 06:54 AM
Dunlap- Clarke Dreadnaught 500 Raymond Solid State 0 19th March 2006 10:14 PM
