I had done JensRasmussen's double side board for testing but find myself too clumsy to solder on the components side. Its so awful that I tried to make a single side version to fit my soldering skill ( clumsy old man ).
Its finished up to all traces and jumpers being laid but when I come to the ground planes, I had some doubts. Wonder if you guys can give some comment on it. The 'a' board is the output board. The left and right ground planes are absolutely 'isolated'. I have added jumper positions between the 5W resistors so as to connected the left and right planes but wonder it would be necessary to do so? The board ¡¥b¡¦ is the main board where I had almost done all the ground planes ( wonder if I can call a ground plane for there are not much space left ). There are 2 ground planes under the 2 large caps but seems to be very much like 'isolated' from the ground planes of 'a' again but they are finally connected at the middle bottom of ¡¥b¡¦. All G planes with components dipping into them should be connected as far as I know but what about all those that are left ¡¥alone¡¦ ? Will they cause any potential problem? Also these plane would go under the fuse too as you can see from ¡¥b¡¦, would that be any issue? Any other problem that you think may jeopardize the board? Tks |
#2 |
Here is the 'b' board
#3 |
hi,
this is the "lo-tim" version, a ground place can be implemented using double sided boards with the top side exclusively for ground....nice and neat.... are planning to sell these boards?
http://www.electronicslab.ph/forum/i...?topic=32688.0 |
#4 |
Hi Tony,
Like I said, I tried not to use a double side. That's why I do it all over again, and now you are telling me to go back to the double side? No, please. Anyway if I am doing the double side, I will have to make plated thru holes all over the board to connect the 'soldering side' G planes to the single 'component side' G plane, is that what has to be done? Lets concentrate on this version. This is the 'super amp' and if anyone is interested, they are always available. |
#5 |
Either it is perfectly flawless that needs no improvement or it is just rubbish that any help would be a waste of time?
Probably making a prototype in a week or 2. Can someone say something about it before I stepped into a s***. Tks |
#6 |
Just forget to asked :
would seperation between traces and G planes at 0.02" be good enough and how low can they go? (some of them are 0.04" at the power and output traces) |
#7 |
I think the traces a bit too thin, specially the solder pads for though hole components is too small for single side board.
| Super Tamp now has board Version B | Marsfrogie | Class D | 6 | 19th February 2008 08:21 PM |
| Another Single Side LM4780 Board.. | Dxvideo | Chip Amps | 12 | 9th February 2007 06:32 AM |
| Ground planes and solidstate? | Nordic | Solid State | 55 | 26th January 2007 11:24 AM |
| Ground planes | Onvinyl | Power Supplies | 9 | 6th March 2006 08:07 PM |
| Ground planes instead of star ground | svokke | Chip Amps | 3 | 22nd October 2003 01:01 AM |
| Page generated in 0.08852 seconds (79.95% PHP - 20.05% MySQL) with 11 queries |
