I have come across an inductor calculator for the zobel network on this forum way back. Life is always like that, when you don't need it, it's flashing up here and there, but when you need it, it's nowhere to be found. Does anyone remember where to find it?
Tks. |
#2 |
Try Calcoil!
http://www.elektroda.net/download/file654.html |
#3 |
It's not really critical anyway... usually wrapping 22SWG enamelled wire around the body of a 10 ohm 2W resistor is about right
#4 |
Hi guys,
I want a 7uH coil so I punched in the #s. It says 40.05 cm, it's cm not mm. Am I using the calculator correctly? Or am I just so dumn? I am actually try to make a coil for the quad 303. Could it be that it is not a air coil? |
#5 |
Here is the calculator
#6 |
It's called CalCoil.
You can down load it here: http://www.technick.net/public/code/...ads.php?did=14
AM |
#7 |
Yes, I had it already, just that its giving me something crazy.
#8 |
Interval between turns is '0' and not the wire diameter unless you want that for some reason. Use "several layers" and set a coil length.
AM |
#9 |
The length will be reduced if you increase the diameter of the coil( because the inductance is proportional to the product L*d) and if you have little spacing between turns.
For 20 mm diameter and spacing of 0.5 mm i get 6 cm length |
| Copper coil inductor vs. round core inductor | tomchaoda | Pass Labs | 7 | 21st September 2011 04:42 AM |
| Simple power inductor calculator | Bootstrapper | Power Supplies | 4 | 26th March 2009 12:24 PM |
| BSC Calculator | hongrn | Multi-Way | 5 | 10th December 2005 05:06 PM |
| here's my new OB calculator :) | hitsware | Full Range | 11 | 12th November 2004 03:42 PM |
| DRD calculator | garbage | Tubes / Valves | 2 | 29th October 2004 02:31 PM |
| Page generated in 0.11018 seconds (71.47% PHP - 28.53% MySQL) with 11 queries |
