inductor calculator
inductor calculator
Old 9th April 2008, 11:07 AM   #11
bigpanda is offline bigpanda  Hong Kong
Intervals between turns is the distance centre to cnetre between each turn which cannot be less than the wire diamenter, right?
If the intervals is edge to edge of each turn, then it can be zero.
Even if I plug into 10mm for coil dia. 1.3mm for wire dia. and 0 for gap distance. I still got 10cm, that is still unreasonable.
Just wondering how it is done in quad 303 .
Old 9th April 2008, 11:54 AM   #12
Terry Demol is offline Terry Demol  Australia
Terry Demol's Avatar
Originally posted by jaycee
It's not really critical anyway... usually wrapping 22SWG enamelled wire around the body of a 10 ohm 2W resistor is about right
Except for the fact that most 2W cylindrical resistors have steel end
caps, in which case it will be a partially steel cored inductor.
T
Old 9th April 2008, 11:55 AM   #13
ashok is offline ashok
ashok's Avatar
inductor calculator
Interval between turns seems to be the distance between the edges of each turn. So if it is a close wound coil the distance is '0'.
Try 'several layers' selection on top. You will get a two layer answer with length of your choice ( 25mm? ).
AM
inductor calculatorHide this!Advertise here!
DRD calculator garbage Tubes / Valves 3 16th February 2016 06:01 AM
Copper coil inductor vs. round core inductor tomchaoda Pass Labs 7 21st September 2011 04:42 AM
Simple power inductor calculator Bootstrapper Power Supplies 4 26th March 2009 12:24 PM
BSC Calculator hongrn Multi-Way 5 10th December 2005 05:06 PM
here's my new OB calculator :) hitsware Full Range 11 12th November 2004 03:42 PM
