Old 6th April 2008, 03:28 PM   #1
Default sunken 2SA1216/2SC2922
hi, anyone have build amp using sunken 2SA1216/2SC2922. i am searching for circuit design using this transistor. pls hlp me.
thank you.
Old 6th April 2008, 03:32 PM   #2
sakis is offline sakis  Greece
sakis's Avatar
Default some versions
of korean INTER M amplifiers were equiped with that outs..... nice devices
never liked interm amplifiers though
whats your expected out ???
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 6th April 2008, 03:59 PM   #3
Default amp
hi, my uncle had a kenwood amp and i saw it was used 12pcs 2sc2922 transistor. i want to use this transistor to make one for my uncle. i never tried this. i know it is very old.
is there any web i can find circuit design for this?
thank you.
Old 6th April 2008, 04:05 PM   #4
sakis's Avatar
Default should i presume ????
that you canibalazied the kenwood amplifier and now you are full of transistors ????
oooo what a pity ....i keep these amps alive ....
any way just tell us a few more like what trafo you have and what is your power requirements
Old 7th April 2008, 09:03 AM   #5
Piersma is offline Piersma  Netherlands
Piersma's Avatar
Default Sanken 2SA1216/2SC2922
The Elektor Ulti Amp uses the Sanken 2SA1216/2SC2922
Elektor's "Ulti Amp"
best regards,
Piersma
Old 8th April 2008, 12:35 PM   #6
Default tried new things on symasim5_3 amp
hi, today i tried on sysasim 5_3 amp using power transistor 2SA1216 and 2SC2922 it works but only gets too hot. do you think i can use this transistor on symasim amp? what else need to chnage?
thank you.
Old 8th April 2008, 04:33 PM   #7
ilimzn is offline ilimzn  Croatia
Default Re: tried new things on symasim5_3 amp
thank you.
Did you check and adjust idle currnt after changing the transistors? Did you sheck if there is any oscillation in the output?
Old 8th April 2008, 11:25 PM   #8
hi ilimzn, thank you. here is the sysasim design and i made change on only power transistor with 2sc2922 and 2sa1216. i dont know is there need to change resistor too. need help.
using 2sc2922 and 2sa1216 power amp? space2000 Solid State 0 3rd April 2008 08:44 PM
### need spice help by 2SC2922/2SA1216 small_boy Solid State 2 5th January 2008 12:47 PM
small 2SA1216+2SC2922 ? lumanauw Parts 3 4th September 2007 05:36 PM
Sanken 2SA1216 and 2SC2922 (again) len_scanlan Swap Meet 0 29th March 2007 08:34 PM
Sanken 2SC2922 & 2SA1216 quasi Swap Meet 2 27th March 2007 10:26 AM
Page generated in 0.09396 seconds (78.52% PHP - 21.48% MySQL) with 10 queries
