Old 5th April 2008, 04:17 PM   #1
ronaldk is offline ronaldk  United States
Send a message via AIM to ronaldk Send a message via MSN to ronaldk Send a message via Yahoo to ronaldk
Default 4 ohm and 8 ohm Speakers
Hello,
I would like to run a pair of 4 ohm speakers and a set of 8 ohm speakers on the same Amp.
How could this be done?
Any feedback and help is greatly appreciated.
-ronaldk
Old 5th April 2008, 05:10 PM   #2
You must be more specific. What is the power rating of the speakers? Are all the same?
Different impedances result in different power share. There are various schemes to connect the speakers.
Old 5th April 2008, 05:21 PM   #3
Did it Himself
richie00boy's Avatar
Short and simple answer is you can't as the amp will 99% likely have 4 ohms as the lowest load you can put on it. If you add another 8 ohm load you will be loading it with 2.7 ohms which it will not like at all, maybe even damage it.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 5th April 2008, 05:44 PM   #4
hermanv is offline hermanv  United States
Overloading the amp is highly dependent on the specific amplifier and how loud it's played. A modern powerhouse amp played at moderate volumes will have little trouble delivering current into a 2.7 Ohm load, but it can't be run at anywhere near the volume it would support with a correct load.
Another, significant problem is that the 4 Ohm speaker will absorb twice the power than the 8 Ohm speaker making the 4 Ohm ones 3dB louder. For the same voltage, current will double at 4 Ohms compared to 8 (since power equals I squared R, I will be 4 times but R is 2 times).
For equal volume the 4 Ohm speaker would need an SPL rating that is 3 dB less than the 8 Ohm speaker.
Also please consider that a 4 ohm rating for a modern speaker with crossover is sort of an average, there can easily be dips below 4 Ohms.
Old 7th April 2008, 01:15 AM   #5
That's what I meant: If you install two 20 Watts 8 ohms in parallel, you get 40 watts, 4 ohms . This assembly can be connected in series with a 40 watts 4 ohm speaker for a total of 80 watts @ 8 ohms.
There are many possible combinations.
Old 7th April 2008, 02:10 AM   #6
You can run them series for 12 ohms. You get less watts, and the 8 ohm speakers would be louder, but it works without overloading the amp.
Old 7th April 2008, 07:34 AM   #7
djk is offline djk
djk's Avatar
You cannot run non-identical speakers in series, it will change the sound of both pairs of speakers.
A really good pair of autotransformers would do the job, but you could buy a small used amplifiwer to run the second pair of speakers for about the same price.
A pair of these would be OK:
http://www.edcorusa.com/products/tra...00/em3300.html
The 8R speaker would hook to the 8R tap, the 4R speaker to the 4R tap, and the amplifier to the 16R tap. This would present an 8R load to the amplifier. If you put 100W in, both speakers will now receive 50W each.
Candidates for the Darwin Award should not read this author.
Old 7th April 2008, 08:26 AM   #8
Dan2 is offline Dan2  South Africa
Does it have 2 be stereo?? if not - then its easy
Studio monitor speakers as Hi Fi speakers? MRod Multi-Way 2 27th March 2009 05:07 AM
Built differences between Guitar Speakers and PA Speakers? agadis PA Systems 7 24th September 2007 08:22 AM
How would you compare your DIY speakers to commercial speakers? AJ Bertelson Multi-Way 20 28th May 2004 03:20 PM
Car Speakers in Theatre Speakers NEED HELP FAST!!! Psionic Multi-Way 9 3rd March 2003 11:11 AM
Page generated in 0.08654 seconds (80.62% PHP - 19.38% MySQL) with 10 queries
