#71 |
rest my case and keep in minde that your testing gear or knowledge about this is limited ....
no probs my friend if sounds good to your ears is perfect for me also ........ but on the other hand i have never seen a vas stage created with darligton any way .... so all of these is totally academic .....plus if we keep in mind that the miller cap is actually conected from the base of the driver transistor to the collector of the output transistor of the all darligton ..... so i am not familiar with this topology also .....
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#72 |
I was thinking about the question of which should come first the cap or the resistor....
My first response was, it should not matter... then it started haunting me... Imagine the resistor is connected to ground side... the side the capacitor sees of this resisor is not at 0V DC, it is at whatever the voltage over that resistor would be at x frequency... With the cap to ground (its internal resistance hopefully much smaller than the resitor) has a closer to 0 potential at the junction point.... I doubt it is audiable, and I certainly don't have the gear to test the validity of this conclusion, I am likely missing something very obvious.... A question for you sakis.... I think it was on one of your boards I once saw a screw on bracket for attatching boards to heatsink... I think you even had it in eagle... if it was you.. care to give me the details... |
#73 |
it seems that i dont remember what are you talking about ....email me
#74 |
What would be the correct order to put these elements at the output of a power amplifier?
-output capacitor (for cheap speaker protection) -output switching relay (headphones out/speaker out) -Zobel 10R / 0.1u -Zobel L/R |
#75 | |
third (or second) -output switching relay (headphones out/speaker out) first -Zobel 10R / 0.1u second (or third) -Zobel L/R fifth - add a resistor to charge and discharge the DC blocking capacitor The combination of 1st & 2nd is the output Thiele Network.
regards Andrew T. Last edited by AndrewT; 2nd March 2012 at 09:35 AM. |
| Do I need a Zobel ? | chasingame | Multi-Way | 22 | 7th August 2009 11:45 AM |
| which cap do you like in zobel ? | sandro600 | Solid State | 2 | 28th January 2007 10:36 AM |
| zobel | Streets97f | Subwoofers | 4 | 19th November 2006 04:44 AM |
| the zobel | bigpanda | Solid State | 9 | 13th May 2006 03:56 PM |
| Page generated in 0.08068 seconds (74.06% PHP - 25.94% MySQL) with 11 queries |
