Old 13th February 2010, 05:31 PM   #11
CrazzyAbtTubes's Avatar
Default use a TL074 or TL072 as sub?
Is it possible to use a TL074 as a substitute? I have an AudioControl EQX equalizer that I was given and some one totally blew it up. 2 4136CP Ic's are split in half!
I have piles of 4558 Ic's and 741's as well, I just want to get this equalizer working to make a sub woofer system.
Old 13th February 2010, 06:09 PM   #12
sregor is offline sregor  United States
I have used TL075 (If you can find them - it's been a while) They are same as TL074 but have same pin out as 4136. Good luck. Steve
Steve
Old 14th February 2010, 01:40 AM   #13
djk is offline djk
djk's Avatar
I used to upgrade the 4136 in Carver products with the TL075 (no longer available).
Now an expensive adapter board and a pair of dual surface mount op-amps are needed.
Candidates for the Darwin Award should not read this author.
AD 846 replacement Fasen Digital Line Level 18 16th July 2009 04:33 PM
MTX 5 ch pot replacement pk386 Parts 2 1st October 2006 04:32 AM
irf 740 replacement bob_v5 Solid State 6 10th December 2005 02:16 PM
looking for a replacement for pcb cad bigpanda Solid State 1 18th September 2004 07:24 AM
Page generated in 0.06063 seconds (71.97% PHP - 28.03% MySQL) with 10 queries
