Old 31st March 2008, 07:26 AM   #1
Default Philips 22AH578 - strange semiconductors
Hello;
I am currently working on a philips 22ah578 amplifier. The schematic of this monster can be found here:
http://www.mfbfreaks.nl/pdf/amps/578/22ah578.pdf
One channel is not working, I already figured out that some of the TO-3 type power transistors are dead.
I am very confused about the semiconductors which are used in this amp, never saw those before and I guess those were OEM made for this project.
The power and driver devices are Toshiba items, the power devices are labeled "355N1" and the driver devices are labeled "357N1" and "357P1". The small signal devices are mostly motorola, also having strange numbers.
Anyone else been working on such an amp before? Which common types can be used as replacements? I`ve read some information about the amp in this thread , so I`m not quite sure if simply taking MJ15003`s is the best way...
thanks, audiomatic
Old 31st March 2008, 08:06 AM   #2
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
MJ15003/4 no good, only 140Vce.
I wouldn't bet my money on Phili using exotic parts, they'd probably picked 2955/3055 if those could have handled the rails.
MJ15022/3 is more like it.
Mr power hour K-amps still has a lot of MJ21195/96: here
Looks like Sponge Bob has killed another thread.
Old 31st March 2008, 10:17 AM   #3
zeonrider's Avatar
Default Hi!
In the past I, have the same problem.
I, put MJ15024/025.
Why, because I, have it.
Still working fine!
Regards zeoN_Rider
Old 31st March 2008, 07:02 PM   #4
jaycee is offline jaycee  United Kingdom
They are probably just "factory numbers" for common transistors. IMO this practice should be banned!
I'd agree, MJ15024 should be suitable as replacement outputs. As for the drivers (looks more like pre-drivers in that topology) what kind of packaging are they in? If they are TO-220 then MJE15032/3 will probably work. If they're TO-126 or similar i'd try MJE340/350
Old 31st March 2008, 07:26 PM   #5
zeonrider's Avatar
Default Hi!
Sorry for MJ15025, forget it.
Driver stage , yes but MJE 15032/3 have deferent pin layout.
You must cross"C" & "B", on MJE15032/33.
Regards zeoN_Rider
Old 31st March 2008, 08:12 PM   #6
The drivers are TO220 and Japanese (green/black), A968/C2238 or earlier types.
Which likely makes the output devices 14MHz Toshiba 2SB600/2SD555.
As they'll cost in the order of $10/pc to replace, MJ15024/MJ15025 or the upgraded MJ21195/MJ21196 types would be the economical substitutes.
Old 31st March 2008, 08:23 PM   #7
Hello;
thanks for all comments, and suggestions.
As far as i figured out right now the drivers seem to be OK.
I will try MJ15024 as pwr devices (first have to order some), and then we`ll see further.
thanks again
audiomatic
Old 31st March 2008, 08:30 PM   #8
spind is offline spind  Canada
Quasi-complementary amp here. The '357N2 and 357P1' transistors are the pre-drivers. The drivers and the outputs are all the same TO-3's --> the 355N1 npn's. (one pair of drivers and 3 pairs of outputs are all on the main heatsinks).
Here's another very useful thread from 'Echowars:'
Oscillating Power Supply....WTH?
Old 31st March 2008, 08:48 PM   #9
zeonrider's Avatar
Default Hi!
Yes it is Q about curent for driving output stage.
At that time when amp. produced it hard to find semicond. for drivers.
Now it is another story.
regards zeoN_Rider
Old 31st March 2008, 09:52 PM   #10
Oops, yes.
I was looking at this picture, the green/black complementary devices should be the pre-drivers.
Makes it only 2SD555 for the outputs.
Philips 22AH578 zeonrider Solid State 4 10th February 2008 08:18 AM
philips cd104 strange problem dm2a Digital Source 0 21st August 2007 07:08 PM
Strange problem with Philips CD753... martipie Digital Source 1 4th April 2006 11:13 AM
Strange problem with PHILIPS CD480 bezobraznia Digital Source 3 3rd November 2005 09:56 PM
Page generated in 0.09871 seconds (81.11% PHP - 18.89% MySQL) with 11 queries
