yamaha dsp a1000 swiching on and off - Page 2 - diyAudio
Old 12th June 2012, 09:35 PM   #11
Now that the amplifier stay on check the voltages with the voltmeter with the voltage selector in AC. Read the voltages and if they are good they should read almost zero. Caution when reading DC voltage in AC it is take a while to settle. This will tell you if you have ripples in the power supplies voltages.
Old 12th June 2012, 09:40 PM   #12
Brouilly's Avatar
Thanks.
I think i'll lug it into work and take a look. Surprised that it just started working, I was wondering where to look next!
Think i'll stick to valves when I can
Broke solderer with delusions of grandeur
Old 13th June 2012, 01:04 AM   #13
I check the schematic for the PRT and when you have time check pin 17 to IC40. It should read zero volts. If it read 2 volts or higher means the PRT circuit it is not working right. It is triggering the shut down.
Old 13th June 2012, 07:12 AM   #14
jitter is offline jitter  Netherlands
jitter's Avatar
Originally Posted by CSlee View Post
Unfortunately it wasn't the supercap. I removed it and the amp still turns on for a moment then dies. However, without the cap the dial movement is random compared to before.
Will check that B+, 15v and 5v are all OK. But as you said, this check ins't done in the first 3-4 seconds.
The random behaviour is to be expected when the memory gets erased.
Check all voltages anyway and don't rely solely on the fault detection for that. I find that if I assume something can't be the cause of a fault it sometimes is.
Update
I replaced the supercap, and no change. But I kept powering up to see if there was any change, and slowly some words popped up on screen. And after about a dozen power ups the amp has now stayed on saying "concert hall A" on screen.
I will leave it on for a while, and see what happens when powering on/off again.
Good idea, it gives the supercap the chance to recharge and gives you the opportunity to check points 1-5 of page 11 of the service manual.
Old 30th October 2013, 09:21 PM   #15
Default Bad resistors found
I had the same problem with the A1000 shutting off. The protection circuitry was causing a shutdown as there were several volts of DC output on the center channels speaker output (measured at the speaker terminals) and on the left channel. After days of testing the voltages using the schematic in the service manual, I found that two resistors had blown and were open: R424 and R351. These resistors are near Q337, one of the large transistors mounted on the large heatsink toward the back of the main board. These are 27k resistors.
Yamaha AX-930 jleaman Analogue Source 6 21st November 2010 11:43 AM
Yamaha cdx 900 stex Digital Source 4 23rd January 2010 11:44 AM
Yamaha MX-70 bekim Solid State 5 23rd April 2007 06:38 AM
Yamaha A-550 angel Solid State 4 18th January 2006 01:22 AM
Yamaha CDX-490 newbie123 Digital Source 1 3rd December 2005 03:31 PM
Copyright 1999-2017 diyAudio
