Old 25th March 2008, 04:09 AM   #1
Default Pre-amp school project, critique me.
Here is my schematic for a school project. I don't know if I have the input set correctly. I will be using a modified wm-61a capsule in series with a 10k resistor , the capsule resistance is 2.2k, on a 9V battery (I have 8V on the schematic because I will be using LED's). Any help would be great. I haven't learned about differential amplifiers yet so I'm teaching myself about them so don't criticize me to harshly. Thanks
Old 25th March 2008, 07:39 AM   #2
Mooly's Avatar
Are you trying to design a discrete component Op-Amp
Regards Karl
Old 25th March 2008, 08:03 AM   #3
Electrons are yellow and more is better!
peranders's Avatar
Your design is right now a bit odd but not totally wrong so it would be good if you could explain how you thought. What is you design goal when it comes to gain and bandwidth for starters?
/Per-Anders (my first name) or P-A as my friends call me
Old 25th March 2008, 10:39 AM   #4
Mooly's Avatar
Had another look, as Peranders say's it is a bit odd. One problem is that for a 16volt supply you can only get around 4v peak/peak output before it clips. It does clip very nicely though . Very soft. Have a look at this. The gain is easily calculated, and it will swing nearly rail to rail. Depending on the gain you choose you may need to add a small capacitor across RF (around 47pf) to keep it stable. A similar value can also be added accross the input resistor, the 47Kohm. A.C. couple your mic capsule (the0.22 mfd cap and keep your 10k feed to the capsule).
Regards Karl
Old 25th March 2008, 11:13 AM   #5
AndrewT is online now AndrewT  Scotland
post4 circuit does not work properly.
the pnp transistor (VAS) forces the two halves of the long tail pair (LTP) to run at massively different currents.
regards Andrew T.
Old 25th March 2008, 11:42 AM   #6
Mooly's Avatar
Hi Andrew, your right about the imbalance of the LTP in fact you've understated it. MASSIVE, it's absolutely ENORMOUS, but the circuit does work and within certain limitations work well. I never intended it to be the ultimate in design . Also the output should really be A.C. coupled as well if it's going to feed into an audio amp. Why not make two, a discrete version and one using an I/C (OpAmp). The circuit I posted is an OpAmp (basic granted) with the bases of the two NPN transistors being the equivalent of the non inverting and inverting inputs.
Regards Karl
Old 25th March 2008, 04:36 PM   #7
Yes it is basically an op-amp and I plan on using it with an RTA for my demonstration. I needed to use a differential amplifier in the project. Using Multisim, I get about a 1V output before it starts to clip with about a 50mV input, which be enough for the soundcard on my labtop. Hope this helps, and Thanks.
Old 25th March 2008, 05:48 PM   #8
Mooly's Avatar
Hi, One further point, having looked at my scrawl earlier, as pointed out by Andrew, there is a rather large (To put it mildly) imbalance in the current distribution of the long tailed pair. Although it will work OK, if you substitute the 1K resistor in the tail with a 5K6 resistor or, better still as it's an educational project a 10K preset pot you will be able to trim the output to exactly zero volts (no signal applied). That imbalance will come down as well and the stability margin greatly improved. I think your going to have to do some practical measurements, do you have a 'scope available. In your previous post (the 140db one) , I suspect you will easily exceed 1 volt output from the preamp.
Good luck with it all, & lets hope it generates some interest.
Regards Karl
Old 26th March 2008, 03:23 AM   #9
Thanks. When I designed the circuit on paper I had 5k6 resistors in there but changed it in MultiSim for a tiny bit more gain. I should have just left it. As for be able to measure 140db, I'm not going to worry about it. I'll never use it above 100db, so I'm shooting for about 110 db input before it starts to clip really bad.
Old 26th March 2008, 11:07 AM   #10
Send a message via MSN to guitar_joe
adding some small emitter resistors to the two transistors in the diff amp might lower the distortion
School Project batkey Chip Amps 8 14th September 2004 02:09 PM
Need help with school project neonmoose Solid State 9 15th June 2004 08:44 PM
School Project Number04 Solid State 10 27th October 2003 04:00 PM
DAC for my cd-pro II school project BrianGT Digital Source 0 8th September 2003 01:45 AM
Page generated in 0.10412 seconds (76.93% PHP - 23.07% MySQL) with 11 queries
