Where to buy heatsinks - Page 4 - diyAudio
Old 29th March 2001, 09:00 PM   #31
Computer heatsinks
I purchased 27 PII heatsinks recently. They were quite nice, and the fan came off easily. If I would use them with fans, I would put them back to back in a long line and pass air through.
A very good thing about these particular units is that they are cerrated, black anodized etc. Should be quite effective even at low air-speed.
Old 7th April 2001, 10:08 PM   #32
arnach is offline arnach  United States
Send a message via AIM to arnach
Default Homebrew CNC Mill
I constructed a homebrew 3-axis CNC milling machine over the course of a few months and it is now operational. It cuts to about 1/64" of precision when I set it up carefully and I have end mills for it ranging from 1/8"-1" diameter off of a 3400 RPM 1/2 HP motor, and the bed is 4ft. by 4ft.
The first thing I did with it was to build an amplifier heatsink. I actually used very simple cuts to cut 1/4" alum 12" H by 30" D panels, and then to cut 1/8" deep by 1/8" wide, 12" into them every 3/8" of an inch. Then i cut 12"H x 3" W 1/8" alum panels and used Wakefield thermal bond to create a bonded fin heat sink. Needless to say it is very large, heavy, and impressive.
I would recommend this to anyone who has the time to do it.
I also have milled 1" thick aluminimum plates and made heat sinks out of them by removing aluminimum to create fins, they are very very solid..
To-3 Heatsinks sandstorm33 Swap Meet 8 6th February 2008 05:33 PM
about heatsinks bigpanda Solid State 2 4th May 2005 04:34 PM
Heatsinks DD_Davo Chip Amps 2 13th April 2005 02:00 PM
Heatsinks Peter Daniel Swap Meet 19 4th February 2004 12:08 AM
Heatsinks for DoZ ultrachrome Solid State 0 4th February 2003 10:23 PM
Copyright 1999-2017 diyAudio
