Old 12th July 2008, 05:51 PM   #41
Until you get it to produce decent quality sound, I'd set the bias to less than 1mv.
Crack open the dead transistors to see if they look like counterfeit parts. It's generally obvious. There's no point in wasting time trying to get the amp to work if you have outputs that are not up to spec.
The audio should have played cleanly at low volume with the lamp in series. When you get it working, look at the audio output to see how it's distorted. Post a photo if possible.
Fuses are cheaper than the outputs. Connect a 1 amp fuse in series with each emitter resistor. They 'should' protect the outputs.
Old 12th July 2008, 08:32 PM   #42
the sound was decent on low volume.
Lets say max turn on the volume 1/4.
then it started to sound crappy.
I really dont think the outputs was counterfiet parts.
i did not buy them from Ebay, bought them from a
small dealer wich sells components to small
companies and stuff....
But i will crack it open, dont have anything to compare
with tought :P
Wrong Voltage / current on BoZ... or Wrong Measuring ? gionag Pass Labs 8 14th May 2008 11:24 AM
Marantz 1060 parts KCravens Solid State 1 29th February 2008 10:12 PM
Marantz 1060 fuse jesserparker Solid State 4 24th January 2008 04:12 AM
Picked up a Marantz 1060. negah Solid State 10 10th December 2007 08:07 PM
First diy project... Balanced operation? and somethings more. rebojorge Pass Labs 4 11th December 2002 02:52 AM
Page generated in 0.06143 seconds (75.99% PHP - 24.01% MySQL) with 11 queries
