Hi, Jenks here.
I've been trying desperately to get a circuit (bass preamp) simulating in multisim for weeks, unto no avail! I was wondering if there is anybody out there whom is rather good at multisim and is willing to assist a confused ( Cheers. |
#2 |
That circuit require a plus and a minus supply.
While the spec sheet says the opamp may be driven from a single 5V supply, your circuit requires a ± supply.
Candidates for the Darwin Award should not read this author. |
#3 |
Hi DJK! Thanks for your reply. I've tried connecting the op-amp to both positive and negative terminals of a battery from both +ive & -ive terminals of the op-amp but that doesn't seem to work either! grr.
Any advice on which op-amps to use with unbalanced audio and how to power them would be greatly appreciated! Thanks. |
#4 |
Alright, I've got two OPA627 op-amps in there now and they're correctly powered but when I alter the potentiometers the gain across the entire frequency response of the input signal alters as opposed to being frequency specific like it should! Grr...
Any ideas? (see attached for schematic) |
#5 |
Forget I said anything! i have it working now :-)
| Multisim 10 Audio Labview | Ted205 | Everything Else | 0 | 5th November 2008 11:58 AM |
| Multisim: Measuring Noise | underwurlde | Power Supplies | 0 | 29th May 2008 09:32 PM |
| Multisim | AR1 | Parts | 0 | 27th May 2008 08:26 PM |
| Multisim simulator library | Twaksak | Solid State | 1 | 28th December 2006 07:49 PM |
| Multisim and Ultiboard -- EWB bot by NATI | jackinnj | Everything Else | 0 | 10th February 2005 04:21 PM |
| Page generated in 0.07356 seconds (73.87% PHP - 26.13% MySQL) with 11 queries |
