Old 7th March 2003, 11:59 PM   #11
Diode is offline Diode  United States
Well, the lm3886 is popular right now but I sure see a lot of blown up ones. I fix pro audio and so much junk uses them. I wonder about their usage and dependability.
My opinion is that they are crap. I prefer STK packs but only use 8 Ohms or they will blow!!!!!
Either that or go descrete.
Chris
The best audio is clean audio!
Old 8th March 2003, 05:03 AM   #12
sangram is offline sangram  India
Originally posted by Diode
...I prefer STK packs but only use 8 Ohms or they will blow!!!!!
Or so I used to believe. I run a pair of STK 4191 in bridge mode, at 42 volt rails, into 4 ohm speakers at party levels (I didn't know better when I built them, about 7 years back) - and now I don't play them that loud, but still into 4 ohm loads (which for each half is 2 ohm, effectively).
But the whole thing has a thermo-fan (not from ESP, my own design using BD139 which is easier to secure onto heatsink, but I digress) and HUGE heatsinks, so I guess that I might be 'overclocking' the chips but they work, so what the heck.
Edit: BTW this is my experience only. YMMV and don't blame me for blown chips.
Old 8th March 2003, 06:59 AM   #13
JAZZ2250's Avatar
Default Re: Best Power op amp
Originally posted by pundip
I have a couple of opa541's but I have seen no info regarding its use in audio. From a purely construction point of view I would like to use the TO-3 packs.
I'm currently working on a subwoofer amplifier using OPA541 in TO-3 package because of the same reason as yours. So far, I have built active crossovers for both right and left channel using TL072 op-amps, and connected low-pass signal (below ~100 Hz) to OPA541. I used the schematic on Amp Chips DIY forum.
I don't have a subwoofer right now. But, I'm going to drive an 8" DVC subwoofer. All the parts are on the way. So, I should be able to describe how it sounds in a week or so.
40A 250V Schottky Power Diodes- Has anyone use in Power Amp to replace Diode Bridge? dtm1962 Solid State 10 15th September 2011 07:38 PM
LTspice tool for power amp power supply component evaluation andy_c Software Tools 2 23rd August 2009 05:10 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
power output calculations, rated power and required power output metebalci Tubes / Valves 7 22nd February 2004 05:49 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
