Old 17th March 2008, 12:41 PM   #1
Default Symasym5 modifid circuit
hi, i am not good in electronics as all of you. i need help for this circuit design. at first i got it from Symasym5 then went to pavel site to have this modofied circuit design. i have build it. now i have modified by adding one more power transistor 2sc5200 and 2sa1943. i circled the design. do you think it is correct way to adding power transistor in parallel? i have posted the pic.
thank you.
Old 17th March 2008, 01:16 PM   #2
may I ask why do you not building the symasym designs of MikeB, AAK, Pavels Mod or others?
I did build several symasyms with Onsemi and Toshiba Transistors based on the "ready for build" design of these people.
Believe me....the only design with better audio quality but less power output is Roenders Amp (heavy modification of the symasym with other design elements).
A well build symasym with MJL 4281 or NJL 0281 will beat any "commercial non-DIY amp" up to the 2000 Dollar price tag.
But, if you want to another "mod", well......I just tried to avoid unnecessary work.
best regards
Alan
Old 17th March 2008, 01:38 PM   #3
Default amp question
hi, thank you for your comments.
actually here in singapore not easy to find those MJL 4281 or NJL 0281 parts. so i used 2sc5200, i know it is not good as those mjl. here is easy to find 2sc5200 and cheap too...only $8 a pare. this is the reason i used this. i am not good in amplifier or electronics, but i like those are hi class amp. honestly tells you, i had one amp that was pioneer, now not working. i used that casing and heat sink to buid one amp. the sound is good but i wanted to use more power to bost my speaker.
i am not so familier with those amplifier. just few days ago started to search to build my own a hi end amp thats all.
thank you.
Old 17th March 2008, 02:22 PM   #4
h_a is offline h_a  Europe
h_a's Avatar
This is a bipolar design. Depending on your choice of driver transistors and their idling currents, you may run out of base current in demanding situations.
If the driver heatsink is up to it, you can crank up the current, however you should know what you're doing ;-)
I'm sorry that I cannot give you more details as I'm do not know the Symasym well enough.
All the best, Hannes
Old 17th March 2008, 02:44 PM   #5
Space2000, your circuit modification should work. Build it.
Old 17th March 2008, 03:19 PM   #6
Default OnSemi branch on SG
quote :
thank you.
As far as I Know there is a branch of Onsemi on Singapore. Have you tried them ?
Here the web : http://www.onsemi.com/PowerSolutions...ountryCode=SGP
and Here is the address :
ON Semiconductor
25 Serangoon North Ave 5
#03-10 Keppel Digihub , Singapore 554914
65-6555-8260 (tel)
65-6482-4794 (fax)
Because I also hope that someone can find NJL0281D in SG...
Old 17th March 2008, 05:42 PM   #7
2SC5200/2SA1943 should work fine in the circuit. I can't belive they would really sound worse then the ON MJL devices.
Old 17th March 2008, 08:07 PM   #8
MikeB is offline MikeB  Germany
MikeB's Avatar
Space2000, the extra pair is added correctly. But, the sc5200 are also tough devices (if genuine). Unless you plan to drive ugly <4ohm speakers and/or increase supply voltage above +/-36v, you can go with a single pair.
Andy, the Toshibas sound absolutely fine. But in my taste the MJL(W)0281/0302 sound even better. I haven't heard the mjl4281 yet.
Mike
Old 17th March 2008, 11:06 PM   #9
Alan
I build the original Symasym with MJL3281A/MJL1302A, another one is a revamp of an old Parasound HCA-800II to a Symasym variant using 2SC5200/2SA1943, +/-50V from the existing power supply.
They sound quite different even though they shared the same circuit skeleton. It is like some girls are pretty and some are not but equally attractive though they eat the same food.
The 5200 has stronger bass, whereas for 3281, the treble is more refined. You have to try out to see which one suit you
Old 18th March 2008, 05:06 AM   #10
Default power supply
hi, my transformer have three line out, which i can get easily +v, -V and gnd but my power supply only 34-0-34. how can i get higher volatge like 68v with -v, +v and gnd?
if we add 34+34 then should be 68v but amplifier need +v,-v and gnd.
thank you.
Please Look at my circuit skybird Tubes / Valves 7 19th December 2008 01:10 PM
555 circuit 24v down to 14v magudaman Parts 7 1st May 2006 12:29 PM
amp circuit help scott3292 Solid State 10 11th July 2005 11:16 PM
Trouble with speaker protection circuit (Randy Slone's circuit) whalefat Solid State 3 13th April 2005 10:13 AM
What circuit? palesha Solid State 1 24th November 2002 10:18 PM
Page generated in 0.10459 seconds (81.59% PHP - 18.41% MySQL) with 11 queries
