One of the channels on my Gemini XPM-900 has stopped working recently, so i whipped the top off to find this:
![]() ![]() It's just behind the red cable in the middle at the top: ![]() Now, to me it looks like a toasted resistor, but I haven't seem that many burnt things, so maybe someone here would be able to tell? Also, has anyone got any idea's what caused this and how to fix it? Also, whats the best way of cleaning the black crap off? |
#2 |
Hello Mike,
That doesn't look good The resistor just below the opamp seem to be OK (just got a little burned) but the opamp looks to have cracked... Try to wipe some of the burned away from the PCB. Maybe it's possible to see/guess what component went up in smoke...
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com |
#3 |
It looks like the op-amp that handles the balanced inputs has gone up, and at a guess, those resistors are part of the regulator circuit that power the opamp.
Here is a service manual: http://www.geminidj.com/disc._prod_m...0-900-1200.pdf Unfortunately - the PCB and schematic diagrams are useless as they are woefully under-size bitmaps To determine if youve got further damage I would remove the blown parts and then try to power on the amp using a series lightbulb. The unbalanced input may still work just fine. |
#4 |
Can you make out the type no of the I/C . Use cotton buds and WD40 initially to clean P.C.B, then use buds and Iso. Can't really make out circuit, but the Op-Amps on left of diagram look like fed from simple series res and zener, no current capability there, the bottom I/C looks to be fed direct of it's own unreg supply ? .Is it this one ? Had another squint, is it the resistor to pin 8 +supply ? If it is would advise change all components on that line e.g rectifier, smoothing, caps filter caps and the zeners. Were you working on it at the time, it's very weird.
Regards Karl |
#5 | |||
![]() Definately looks like a resistor that went bang IMO. Quote:
Do you have info on how to test with a lightbulb? I can try unbalanced, as it's got TRS and XLR in's. Do you just wire a 100W lightbulb to the speaker outs? Quote:
![]() Unfortunately I cannot make out what is going to what pins on the opamp, as it seems all the op amp pins seem to be on traces on the other side of the board... I will to take the PCB out tho, as there could be burnt bits of resistor under there... |
#6 |
Hi Mike, think it was Jaycee that mentioned the bulb trick, anyway you use the bulb to limit the current the amp can draw. Try a 60watt bulb (filament not energy saver
#7 |
What test equipment do have ? If you have meter measure on low ohms (amp off) for continuity from pin 8 and then pin 4 of that I/C to one end of the where the burnt part was. Is this where it goes to ?
#8 | |
I'll give the light bulb method a go... I'll try and test the resistance to pins 4 and 8 of the op amp right now, gimmie a min. |
#9 |
I think it seems more like a blown Zener
#10 |
Ok, I can't actually get the probe to connect, as there are just holes as I pulled the burnt resistor... I'm gonna have to pull the PCB to do this...
I'm gonna try the bulb then first, then pull the PCB. I did manage to find another burnt part while looking around tho. ![]() Looks like I may be needing a new tank cap! |
| tone arm replacement on gemini XL 500 II | jtwell2 | Parts | 0 | 1st August 2008 11:58 PM |
| gemini GX-350 Powered Speaker | JDogHerman | Solid State | 4 | 28th January 2008 09:20 PM |
| blown gemini mixer - need help | pejinm | Chip Amps | 3 | 11th August 2007 03:29 PM |
| Gemini proved crossovers? | Hisatugo | Multi-Way | 2 | 7th March 2004 01:20 PM |
| Any Dynaudio Gemini owners ? | H o m e r | Multi-Way | 3 | 25th September 2002 12:48 PM |
| Page generated in 0.12444 seconds (83.01% PHP - 16.99% MySQL) with 11 queries |
