Hi Guys or Mr. Hansen,
is it possible to built a line preamp with the topology of Ayre V3 proto if i replace all mosfet with Jfets? Thank You! Maxpou |
#2 |
Hi guys,
this is the schematic, i don't need balanced input. Does it can work? Thank you! Maxpou |
#3 |
Hi Guys,
i test the circuit but i have a problem with my dc offset. I adjust with my R8 and R9 for 0Vdc at the output without signal but i input signal my dc drift at output. Why? thank you! Maxpou |
#4 |
My schematic with value of components. Thank you! Maxpou
#5 |
In principle, you can use the amp's topology to create a preamp, but I don't see that you're following the V3 topology--at least as I remember it. If I have time, I'll dredge up the schematic and see if I'm right.
You're putting a signal in the Source of Q3 & Q4 and taking it off the Gate? There are several oddities about your schematic. Grey |
| preamp topology | gearheadgene | Solid State | 22 | 23rd June 2011 09:17 PM |
| topology for preamp, single ended or complimentary | maxpou | Solid State | 7 | 10th January 2008 10:41 AM |
| Oen loop preamp topology questions | bogdan_borko | Solid State | 0 | 3rd December 2006 07:02 PM |
| Preamp topology regarding placement of Pot | dine1967 | Chip Amps | 1 | 13th April 2006 07:23 PM |
| Ayre style X-Preamp? | aparatusonitus | Pass Labs | 22 | 22nd October 2005 12:12 AM |
| Page generated in 0.08029 seconds (73.61% PHP - 26.39% MySQL) with 11 queries |
