#11 | |
I'd rather suggest Smyasym as AndrewT did. |
#12 |
A third vote for the Symasym.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#13 |
so many options! whew!
#14 |
The crew (MikeB the designer, and the others) in the Symasym thread are looking really kind and helpful. I'm sure they'll help you!
#15 |
this is the link
Official LYNX Power Amp builder’s thread I know this amp maybe "over power". for you |
#16 |
The Design
Let me start by pointing out, that LYNX project from the beginning in 2002 had only one goal! To create a rock-solid and powerful sonic Power Amplifier like those used in studio's......... So if you are fond of the deceased mighty and "muscular" power amps from Phase Linear, SAE, GAS, Dynaco and similar ones, and if you like listening to live recorded LP's and CD's, you may be intrigued by this project as the result is very close to those. Components Components shown in the schematics are only suggestions. The circuit has shown good characteristics and produced good and clear sound when build with very low cost components. So with this circuit you have the possibility to either build a low cost dynamic Power Amplifier or a Studio Class Power Amplifier. that's what i get in the homepage this is the homepage http://www.audio-circuit.dk/ |
#17 |
So it looks like I might need a higher power amplifier like the Lynx after all...The monitors that I am building are 90dB D'Appolito styled MTM's. Any other suggestions for a studio monitoring 250W - 300W amplifier thats well documented and easy to source?
#18 |
I don't think the consensus is suggesting that you need 250W to 300W for your 90db/W/m speakers. I would aim for 100W to 150W for the levels I listen at and still ensure 20db headroom for the occasional transient peaks. You may find that as little as 50W will satisfy 95% of your listening needs. You have to decide if you need 3db more or 7db more.
regards Andrew T. |
#19 |
Yes you are correct AndrewT, I guess 250W is overkill. I was looking for about 20dB to 24dB headroom so I stand corrected that about 100W - 150W would be adequate. One option is the Lynx 3.0 adapted for about 150W.
#20 |
Hi Moksha,
Have a look at RMI-FC100 amp by roender in the threads here, very accurate & with powerfull bass. Its a tad more complicated than others here but youll be very hard pressed to find a better sounding class AB amp here. Alex |
| Studio monitor | sueyuen3 | Multi-Way | 4 | 13th April 2009 02:13 AM |
| once again studio monitor | holger honda | Multi-Way | 17 | 4th August 2008 04:46 PM |
| studio monitor ... | Ahmad_tbp | Multi-Way | 27 | 15th September 2006 07:46 AM |
| Studio monitor | gev | Instruments and Amps | 30 | 17th January 2006 06:53 AM |
| DIY studio monitor | mgoedeke | Multi-Way | 4 | 22nd June 2003 02:29 AM |
| Page generated in 0.08588 seconds (87.21% PHP - 12.79% MySQL) with 10 queries |
