Old 13th March 2008, 09:03 AM   #1
Gravenstede's Avatar
Default maplin mosfet GA28F upgrades?
hey-hey
iv got two home made monoblocks using the good old maplin GA28F mono boards
they have a 1kw dougnut and 6 BH or BHC? 15000uf 63volt capacitors each,
3 for the power supply and 3 for the output stage?
the GA28F's have the Exicon transistors 10p16 and 10n16
the two main capacitors on these boards [c11 & c9] are 63v 220uf(m) made by dubilier
is there a chance of upgrading any of this to improve sound?
the sound at the moment is fair but not as good as my sansui AU-919 which i know is a top amp but its 1979 technology afterall
im testing my amplifers with IMF tls80 monitors
thanks all
Big + Old = Good! with HiFi - Yes / With Women - No
Old 13th March 2008, 11:43 AM   #2
they have a 1kw dougnut and 6 BH or BHC? 15000uf 63volt capacitors each, 3 for the power supply and 3 for the output stage?
No, 3 for + rail and 3 for - rail!
Simple upgrade hints:
Polyester input capacitor + high-quality elko in the feedback + ceramic-NP0/mica compensation capacitors
Old 13th March 2008, 12:57 PM   #3
jaycee is offline jaycee  United Kingdom
The Maplin amp is basically a copy of the Hitachi sample note for the original output MOSFETS.
I'd say build a better amp. http://www.wnaudio.com/amos100.pdf would be ideal.
Old 13th March 2008, 05:04 PM   #4
burbeck is offline burbeck  United Kingdom
hi
a quick upgrade would be to replace the output mos fets with dual die parts, these are drop in replacements, equivelent to 2 parallel parts in one case
try BUZ900D and BUZ902D pairs
or ECF20N20 and ECF20P20 pairs
the Idle current will need need adjusting to double what it is now I would suggest 200mA. with either of above pairs.
with this module i recommend replacing the R15, 4R7 3 watt with a non inductive (non wirewound part) i use 8R2 2 watt.
this helps with hf stability.
regards
bob
Old 14th March 2008, 03:13 AM   #5
I wouldnt recommend that. The MOSFETS are driven directly by the VAS stage in this design. Adding dual die outputs will load the VAS further, and distortion will rise.
You could try this with the White Noise amp I linked to, but to be honest one pair on 50V rails is plenty
Old 17th March 2008, 06:34 PM   #6
i have used parallel mosfets in this circuit no problem, im sure im not the only one
regards
bob
Maplin 150w MOSFET regulation? Craig405 Solid State 59 4th March 2012 08:30 PM
Maplin 100W mosfet amplifier - power supply problem HBrunt Solid State 8 21st October 2011 01:04 AM
Maplin mosfet problems bobcat Solid State 1 15th July 2009 08:58 AM
GA28F Mosfet Amp hungeryhippie Solid State 7 5th May 2007 03:57 AM
Maplin 4-20 Trebla Tubes / Valves 14 28th January 2006 04:14 PM
Page generated in 0.08331 seconds (77.54% PHP - 22.46% MySQL) with 11 queries
