Old 12th March 2008, 09:41 AM   #1
rubydac is offline rubydac  Hong Kong
Send a message via MSN to rubydac
Default discrete jfet input opamp
From 2sk389 jfet input used output from drain pins of them instead output of ne5534 by cascode to pin1/8 and short input pin 2/3 of ne5534 to ground !!!
So now you have jfet input opamp instantly !!!
I took it from studio amplifier (**,*** USD)
Old 12th March 2008, 10:06 AM   #2
Electrons are yellow and more is better!
peranders's Avatar
This is a classic solution from the stone age. You can find it in application notes from National from the 80's. Nothing you will do today since the opamps got much better.
/Per-Anders (my first name) or P-A as my friends call me
Old 12th March 2008, 10:14 AM   #3
Lightbulb Give me some link
Please Mr.perander send me some link which used this schematic.
I find all of same as this method but I never seen about this ?!?
Old 12th March 2008, 01:12 PM   #4
jackinnj's Avatar
You have a wonderful description of this paleolithic circuit in Walt Jung's "op amp applications" -- should be on everyone's bookshelf.
Old 12th March 2008, 01:25 PM   #5
peranders's Avatar
Default Re: Give me some link
http://www.national.com/an/AN/AN-222.pdf
There is also an app note in an old Siliconix application book but it's hardly to befound on the net. I have this app note somewhere. The idea is the same as the link above but JFET's were used and the opamp was NE5534.
http://www.analog.com/library/analog..._handbook.html
http://focus.ti.com/lit/an/slod006b/slod006b.pdf
Old 12th March 2008, 04:59 PM   #6
Smile super thanks
Thanks a lot Mr.Peranders
Could you suggest me to use this schematic in tube amplifier ?
990 discrete opamp udip Solid State 18 12th February 2009 11:00 PM
Discrete JFET regulator problem lineup Power Supplies 8 30th July 2008 04:59 AM
My discrete opamp udip Solid State 51 8th August 2006 07:33 AM
Page generated in 0.08456 seconds (73.24% PHP - 26.76% MySQL) with 11 queries
