Old 11th March 2008, 07:34 AM   #1
Default 4 channel amp power supply?
Hi folks,
I have a question which hopefully you can help me with.
I am designing a 4 channel amplifier which should be capable of 100 watts into each channel at 8 ohms. I have designed the amplifier to use the Avel Y236903 800VA 40V+40V toroid, but I realize now that the DC voltages into the amplifier rails is going to be way too high. I am measuring 49.5 volts from the secondaries (spot on, btw) which according to my calculations will rectify to approximately 70 volts!
The amplifier is a standard class AB design using complementary MOSFETs (IRFP240 and IRFP9240s to be exact), and for the power output I want I should need a rail voltage maximum of around 40 volts peak for 100 watts into an 8 ohm load.
My question is whether or not this toroid would be acceptable, or should I choose a toroid with a lower voltage and higher current. If I decide to stick with the toroid I have, what would the long-term consequences be? I assume the limited output current of the toroid would simply cause a large voltage drop on the output and would otherwise run hot, but so long as the voltage doesn't drop below the voltage needed for continuous power output, could I get away with having too high a voltage on the rails?
Thanks for you help!
Old 11th March 2008, 07:49 AM   #2
Nordic is offline Nordic  South Africa
Nordic's Avatar
For 70V you will want at least 3 output transistor pairs.. to be safe.
by the time you draw that transformer har engough to get rails to 40V, I suspesct you will be throwing the transformer away... or recycling as scrap copper...
Old 11th March 2008, 10:08 AM   #3
Yes, I suspect the thermal dissipation would go way up...
additional output pairs per channel isn't really an option, due to cost. I guess I'll be finding another toroid
Old 11th March 2008, 11:20 AM   #4
Nordic's Avatar
Surely 4 transistors costs less than a toroid
Old 11th March 2008, 02:29 PM   #5
By this I'm guessing you mean multiple transistor pairs per channel. With 4 channels, that would be a huge amount of mosfets. Not only would mounting all that be hard, but at around $6 a pop, 24 transistors would cost roughly the same as a proper toroid.
I've decided I'm going to return the toroid to parts express and I will replace it with this: http://www.toroid.com/standard_trans...n2.htm#782.302
The additional current should be quite useful to ensure close to full power output from all channels despite the lower voltage.
Old 11th March 2008, 05:06 PM   #6
AndrewT is online now AndrewT  Scotland
I used a 40+40Vac transformer to power a 3pair Leach and it gives 170W into 8r0.
regards Andrew T.
Old 12th March 2008, 09:28 PM   #7
What about adding some primary turns to lower the secondary voltage?
Old 13th March 2008, 02:37 PM   #8
Send a message via MSN to Kevin_Murray
Default "Mod" the transformer
I was in the same situation last year when I needed a transformer for my amp. I had 75V caps but my transformer was an isolation unit (60+60). What I did was power it up alone and use my multimeter to poke the secondary wires until I found a better place to tap into the secondary windings. I now have +/-52volts which is fine after rectification. The problem with adding primary windings is that they are almost always the inner winding, so you can't get at them. Besides you would have to add a lot of windings for a few volts decrease in output. Easier to modify the secondaries.
Kevin Murray
Old 14th March 2008, 03:24 AM   #9
jaycee is offline jaycee  United Kingdom
Modifying the primary winding is dangerous - you could easily compromise the safety of the transformer.
Bear in mind that if you unwind the secondaries, you are no longer making efficient use of the transformer core as the windings will no longer be evenly spaced over the core.
Personally, I'd just sell the transformer and get the right one - or keep the other transformer and have an excuse to build a higher powered amp or subwoofer later
Old 14th March 2008, 01:22 PM   #10
Craig405's Avatar
I guess your after about 50-55V for normal operation?
Is the transformer loaded?
You might find it drops to more like 40V when you draw some current from it?
edit.. Just read your after 40v rails.
Help with 8 channel Leach Amp Power Supply bowdown Power Supplies 7 29th July 2009 12:41 AM
Tripath 5 Channel TA3020 Amp Board with Power Supply john65b Swap Meet 11 12th December 2007 02:55 AM
need advise: 3-channel tripath with 12V power supply smoerk Class D 7 17th August 2007 03:06 PM
Sonic impact t amp - supply voltage on the output of one channel deiksac Class D 6 7th April 2006 10:07 AM
Power Supply for 5 channel Gainclone Gcollier Chip Amps 3 25th March 2003 08:53 AM
Page generated in 0.09817 seconds (80.70% PHP - 19.30% MySQL) with 10 queries
