Old 10th March 2008, 10:58 PM   #1
Kolloi is offline Kolloi  United Kingdom
Default Make a power amp out of op-amp ICs in parallel?
I was thinking about designing a transistor power amp, when the thought occurred to me that it would easier and cheaper to just buy a load of op-amp ICs such as LM481 and hook them up in parallel. If I put a diode in line with the DC power to each IC, then it should be safe.
Is this feasible or am I overlooking something obvious and important?
Old 10th March 2008, 11:17 PM   #2
Tim__x is offline Tim__x  Canada
I'm not sure what you think the diode will do, don't use it.
All you need is to make sure the dc offset between channels is low, and to ensure stability, depending on topology current sharing output resistors may also be needed.
I can't remember the name, but I recall a Scandinavian designer on head-fi building such a thing.
Current is limited only by patience and budget, so the max supply safe supply voltage will tend to limit output power.
Old 10th March 2008, 11:27 PM   #3
What are the diode used for?
You must use current sharing resistors. The output power will be limited by the supply voltage, not the current capability of the parallel amps.
Old 10th March 2008, 11:29 PM   #4
I found what I was thinking of, it was Jan Meier posting on Headwize.
Here it is.
Old 10th March 2008, 11:41 PM   #5
Wow! So it would work.. That's excellent. I'll leave the diode out and just build it, bearing in mind that each op-amp IC has to share the current from the power supply equally. Thanks a lot guys.
Just one more quick question: roughly what level of current in excess of the safe operating limit for an average opamp is required to destroy that opamp? I want to have a rough idea how far I can push it.
Old 10th March 2008, 11:46 PM   #6
jaycee is offline jaycee  United Kingdom
If what you want is a power amp which is easy and cheap to construct, why not just build a Gainclone type amplifier ?
You wont get much more than 15V rails out of simple opamps anyway, and not a lot of current.
Old 11th March 2008, 12:29 AM   #7
Thanks jaycee. I hadn't heard of 'Gainclone', so after you mentioned it I Googled it. It seems that building a Gainclone-type would definitely be the most straightforward solution.
Old 11th March 2008, 05:11 AM   #8
Here it is.
It uses some pretty badass OP-AMPS to begin with, even before parallelling them.
Old 11th March 2008, 06:20 AM   #9
jcx is offline jcx  United States
lots faster, higher current competition today, LT1210, LT1795, TPA6120 -and you can effectively heatsink them:
http://www.diyaudio.com/forums/showt...t=#post1392458
Old 11th March 2008, 06:41 AM   #10
Kolloi, on 25v rails an LM3886 IC is easily good for 30W into 8 ohms, the parts count is low and the sound quality is rather good. This sounds like it fits your needs exactly
You can get LM3886 for about £5 each from Farnell, or maybe a bit cheaper on eBay if you can find them.
Parallel Mosfet for Hi Power Hi Speed Car Audio 23 30th January 2012 10:24 PM
Power Trans Winding Parallel AC or DC? sylin Power Supplies 11 3rd March 2009 09:09 AM
Parallel-ing Switching Power Supplies JohnT_diy Power Supplies 11 7th July 2007 04:00 PM
Parallel a dual power supply or two power supplies? Thunau Power Supplies 12 16th February 2007 04:21 AM
Parallel power transformers? paulb Solid State 12 19th October 2001 09:25 AM
Page generated in 0.09243 seconds (79.51% PHP - 20.49% MySQL) with 10 queries
