#231 |
Hi Jay, I remember the Stochino amp when it first appeared in Wireless World, a somewhat frightning beast, and all those IN4148's too. Didn't some have to be selected for low leakage at voltages above their ratings.
It's good you are having a go, and I don't think you will be disappointed with the sonics.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#232 | |
In the UK we have DAB radio at appaling bit rates... radio 3 (classical) and "Classic FM" are the only two that use rates of 192kbs (barely adequate) and 160kbs respectively. Other popular stations use 128, and some down to 64kbs in mono. And this is where the amp still shines... the music come through. Yes the transmission imperfections are quite audible, but the musical experience still comes across... something that absolutely eludes other amps I have used/built. It's hard to put into words... you'll know when you hear it
#233 | ||
But I don't know, I want a mosfet amplifier. Very difficult amplifying devices but I have a high hope on them. Tubes are too slow for me (except probably those I cannot afford). Lateral mosfets are faster than tubes but slower than the other transistors (and linear too). Slower devices tend to be musical and good on vocal and jazz. Faster devices (such as implemented in the Stochino) are better for orchestra, but this kind of music requires big multi-way loudspeakers, something that I don't have, and a music that I don't listen to. |
#234 |
Hi Jay... you'll only know by building it.
What I can virtually guarantee you, is that it will provide a totally different presentation of the music over anything the Stochino or similar designs can provide... totally compelling and engaging to listen too.
#235 |
Thanks Mooly. Now I'm confused whether I have to go with permanent "slow" building or one day point to point so I can hear it ASAP
For permanent building I will need days to work on only the layout. I have prepared the heatsink and the fiberglass veroboard. The holes are made for TO-5 because I want the final one to use K135/J50. But for testing I will use TO-220. And I'm worrying about the pre-amp. I will guess that this amp will need a preamp, which I don't like to use, especially opamp based which seems to work well with amp like this. I'm thinking about building an integrated, with 5678 Aikido (or those 12AT7s that I should have not bought). But I will think about it later. I have a plan to build my own preamp. About DC servo, I don't have TL071, but I have TL072s that I can use mono, but I prefer to use my other single opamps. Since I want the highest supply rail possible for the amp, I think I will have a dedicated off-board PSU for both on-board opamps (or may be to put the PSU board on the veroboard). I think I will use LF356H that I think is a fet-input one, or those from Analog Devices. BTW, do you think I should build a speaker protector first? May be I should because sooner or later I will need it to protect my discontinued drivers. But I'm very reluctant even tho the components and PCBs I have are more than enough. Ah, stupid question ![]() Mooly, can you describe your speaker? I think "mosfets" don't work at its best with small speakers. |
#236 | |
1) Inadequate crossover that allows too much low frequencies -> moves tweeter dome too much -> creates huge distortion. Quite a common one that. Decent pro-audio piezo can be very smooth funnily enough - its natural roll off usually prevents any chance of same happening. 2) A non linear amplifier (class B rather worse than class A) with high gain being held together with a big loop feedback loop. Distortion can only be moved - not reduced, so if you need to run more than about 10dB to make your amp linear then it will always sound fatiguing, partly from the non linearities and partly from the feedback. |
#237 |
Hi Jay,
Speakers I use are these, which have a 3 ohm minimum impedance. View the 703 at Bowers & Wilkins - The World's leading Hi Fi Brand http://www.bowers-wilkins.com/displa...098&terid=1118 The amp will work just fine without a preamp if used with a CD player etc. Just use a 10 or 22k pot as a volume control. The feedback factor is low, and corresponding input sensitivity high. 22k and 470 ohm for the feedback equates to a voltage gain of 48, or 33db if you prefer. The DC servo. First it must be a FET opamp that you use, not a bjt. The power supply for opamp only has to be sufficient to provide the bias for the input transistor, so -12 volts is perfect as the output of the opamp will be around -5 from memory. If you use an IC that can't work with the + input (pin 3) tied to the positive supply (pin 7) when running on a single supply then you will have to provide a split supply for it, in other words -/+12 volts. The TL071 and single zener seemed the most elegant engineering solution. The LF356 should also work correctly I suspect. Remember the opamp isn't in the audio path as such and it's AC characteristics are not important... apart from the high input currents a 741 would be just as good here. The opamp won't affect the sonics. A separate PSU for it is not required. It's perhaps good practice to include DC offset protection, however lateral FET's are amazingly rugged, so if you have confidence in your construction abilities then I would say it's up to you. I did include offset detection, but that was me wanting to make a complete "job" of it all. What is ESSENTIAL for a finished amp is the relay delay at power up as the servo takes a few seconds to settle. This can be a really simple design, little more than a power transistor with an RC network on the base to give the delay. As simple as that.
#238 |
Should mention the B&W's are what I have used for the last 5 years or so. When the amp was first designed I used Celestion SL100's and SL6's
Stereophile: Celestion 100 loudspeaker
#239 |
It is possible to greatly improve rail efficiency (output swing) of this amp by making CFP an over-unity gain stage with a gain of about 1.15-1.25. Easily done by adding two 1.5k 1W resistors from emitters of Q6/Q7 to the ground. Such small gain will have negligible effect on both THD and phase margin.
It is particularly suitable for this amp since Q6/Q7 run very little current, thus power dissipation in Q6/Q7 emitter dividers (for over-unity CFP gain) is small. |
#240 | |
In my experience B&Ws can be improved greatly in the midrange by adding some decent stuffing behind the mid driver. Usually there are a few wisps of white poly foam, whereas pure wool would be the way to go here. Extra braces are also good. |
