My MOSFET amplifier designed for music.
Old 29th November 2012, 02:10 PM   #381
Ian Finch is online now Ian Finch  Australia
Since you introduced a MOSFET output relay as an option, could you not also delay its switch-on, as with an electromechanical output relay?
(or otherwise disable until the amp. has settled)
Ian
Old 29th November 2012, 05:35 PM   #382
Mooly's Avatar
Hi Ian,
Yes that could easily be done. The only reason I didn't push the solid state relay this time was that it introduces another diy aspect to the amp. To keep it simple they need the photovoltaic couplers, to do it without and it becomes more complex such as Pavels' design here,
Output Relays
The solid state relays are linked to in "item 3" on post #1 of this thread.
Old 1st December 2012, 01:40 PM   #383
alex mm is offline alex mm  Romania
alex mm's Avatar
..... some missing files attached .
Alex.
Old 1st December 2012, 02:10 PM   #384
Mooly's Avatar
Many thanks for those Alex. They look great.
Old 1st December 2012, 07:53 PM   #385
Preamp is offline Preamp  Germany
Preamp's Avatar
Alex, keep up the great work! You're truly a master!
Here's an example for the feedback takeoff point Mooly mentioned. Maybe you can move the affected components a little?
Best regards,
Lasse
Old 4th December 2012, 06:56 AM   #386
gmphadte is offline gmphadte  India
Last edited by Mooly; 25th November 2012 at 01:08 AM. Reason: Index to relevant areas in the thread.
The post #1 in this thread has been edited recently and is a nice thinking.
I wish this was the case for other enormous length threads.
Gajanan Phadte
Old 4th December 2012, 10:15 AM   #387
post385
R14, the NFB upper leg resistor, can be soldered onto the Ro lead as it comes out of the output rail trace.
That ensures it reads the output voltage.
regards Andrew T.
Old 4th December 2012, 12:28 PM   #388
Mooly's Avatar
Originally Posted by AndrewT View Post
post385
That would be ideal.
Old 4th December 2012, 12:29 PM   #389
Mooly's Avatar
I've done a "sort of simple" universal speaker delay circuit here as I often mention the need... but never show a circuit.
Simple Universal Speaker Delay Using A Triac
Old 8th December 2012, 12:53 PM   #390
JohnGeneva is offline JohnGeneva  Switzerland
Hi Guys, I went over Alex PCB design and schematic and R10 looks like inadvertently it was put on signal ground instead of -45v. Was this a mistake?
I made a bom and will upload if others are interested. If so, what value should I put for the feedback resistor as per post 385.
Alex, you willing to review? It would be hard for me to build without pcb as I have never built amp without pcb.
Best to all, John
My MOSFET amplifier designed for music.Hide this!Advertise here!
