My MOSFET amplifier designed for music.
Old 18th June 2008, 11:13 AM   #121
Mooly's Avatar
Hello Michael,
Slow down To have it playing you must have the outputs connected up. Yes ?
Read carefully,
Measuring the voltages across R17 and 22 (without the outputs connected) was just a way of checking that all was working O.K.
Did you move those 270 ohm gate resistors up to the legs on the FET's by the way. Good !
With the FET's connected and the pot set back to zero ohms is the output at zero volts DC. Do not connect any speaker while doing this and have nothing connected to the input as well. Post the reading I am interested in what it is
The pot is used to set the current in the output stage -- not voltage-- and the easiest way to set this is to measure the voltage across one of the 0.22 ohm resistors that go to the FET's.
You need to turn the pot to give around 22 millivolts across either resistor, it does not matter which you use. That will give a current of 100ma - dont worry if it seems to alter as the FET'S warm up -- just get it somewhere near.
Let me know how you get on.
Old 18th June 2008, 11:24 AM   #122
lumanauw is offline lumanauw  Indonesia
diyAudio Moderator Emeritus
lumanauw's Avatar
Send a message via Yahoo to lumanauw
Hi, Space2000,
I saw your picture in post#111, it's better not use those long extension wires. Especially the gates of a mosfet, should be very short to the driver.
Old 18th June 2008, 11:28 AM   #123
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
David means that you can safely do that with Vertical MOSFETs, but with Lateral MOSFETS it is Off Limits.
If you manage to keep it from oscillating like that you're One Cool dude.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 18th June 2008, 11:43 AM   #124
Mooly's Avatar
Space is the Veroboard King around here.
Old 18th June 2008, 11:46 AM   #125
Mooly's Avatar
Hi Jacco, I said it was stable, even like that Did no one pick up on the wiring in the Photo to the FET's.
Old 18th June 2008, 01:35 PM   #126
space2000 is offline space2000  Singapore
hi mooly,
As you have seen on the picture, it was only for showing that it is assembled. Actually I had changed the cables into very short and all are separated. I had to change where ever as it’s require. it’s operate quite cold, not really gets hot. I don't know why you all worry about vro-board. I even made 500w RMS used only vroboard, microchip with LCD and it is operating very, very well. I made for my uncle with two pair of 2sc5200/2sa1943 sumsym amp using 70v and he is using almost three months now without having any problem. That was also on vr-board but well constructed. Until now he is very pleased with that amp. I even got surprise the sound quality coming out from that amp, very clean.
I never use only vro board. I use some places thick copper plate to have higher amp where ever need to use.
Mooly actually i need to do more and check more. I just made it just try to get the sound first then later I will tune more btr for performance. This is the way I do all time.
Thanks for your help. Sound will be more btr when I will use proper circuit and power supply.
Great amp, very nice….
Best regards,
michael
Old 18th June 2008, 04:37 PM   #127
Mooly's Avatar
Hello Michael,
Pleased to here you have got it all working. Just remember to recheck and adjust the pot as before for 22 millivolts if you run it on a higher voltage supply.
Run's a bit cooler than the Class A
Well done.
Regards Karl
Old 19th June 2008, 12:32 PM   #128
hi mooly,
today i have tuned even more btr then last time. it will takes time to do. now even more nice music sound can produce. the vocal still not get sweet. now i am operating on 36vdc. heat is not get worst. quite stable now. bass is not very deep. anyway over all very nice, very musical..
many thanks for help.
best regards
michael
Old 19th June 2008, 12:42 PM   #129
Mooly's Avatar
Hello Michael,
You still having fun Do make sure you do as per the previous post, if you have not got the 22 millivolts across the 0.1 ohms there will be crossover distortion.
What I did not show on the circuit was a 10 ohm 2 watt across the output coil. It should really be present but may not make any audible difference.
Have you grounded it all properly, keeping the input and PSU ground "separate".
Old 19th June 2008, 11:34 PM   #130
hi mooly,
i didn't understand which one you are rfring about 0.1 ohms. i did correctly the zobel, i use 2watts 10ohms. there is no problem.
thank you.
My MOSFET amplifier designed for music.Hide this!Advertise here!
Copyright ©1999-2017 diyAudio
