hi guys whats the best way to build a dummy load?
thanks chris |
#2 |
Depends on which resistance you need and how much power you need.
For instance I am using 14 resistors in parallel, every resistor is 56ohm 10W to give me a load of 4ohm 140W. When I use it for really high power I put the resistors in a can full of water. When you use 300W or more you see the water boiling It is good for short power tests but of course not for continuous load at more than 50W. |
#3 |
#4 |
Pictures of small dummy load
#5 |
front
Name covered up to prevent spam. Unit has two EBG type UXP/600/9 4 ohm resistors rated at 600 watts each. Unit has switch for 4 or 8 ohm load and right or left channel monitor. |
#6 |
Picture of big load
4 EBG 600 watt load resistors per channel in a series parallel for a 4 ohm load per channel. The unit can also be used as one massive 8 ohm load if needed for large bridge amplifiers. It is cooled by 3) 5" Dayton 70 CFM fans and never gets warm no matter what. |
#7 |
#8 |
UXP SERIES Power Resistor
EBG has developed a small unique package (60 mm x 65 mm) that can handle up to 960 Watts continuously when mounted to a heatsink with a bottom case temperature of 70°C at full power. They have 3 different models available; 300W, 600W, and 800W, all using the same unique packaging. The catalog power ratings are all shown for an 85°C bottom case temp, however if you are able to keep the bottom case at 70°C you can acheive a 20% increase in the continuous power capability. This resistor was designed for the high-speed trains in Europe, but is one of the fastest growing lines here in North America. This patented package offers electrical advantages as well as physical advantages. The ohmic value range begins at 0.5R up to 1M. The dielectric strength can go as high as 12 kVrms and the partial discharge up to 7kVrms < 10pC for 30 seconds. Although the standard terminal heights are offset at 30mm and 32mm there are many other terminal heights and options available. Easy mounting with 2 screws to the heatsink is also an advantage to our UXP series as it has an internal calabration to apply equal pressure to the heatsink with only those 2 mounting screws. This thick film resistor can save your company time and money. Check their detailed spec sheet or call them for many additional options not listed. -------------------------------------------------------------------------------- |
#9 |
hi, What do these resistors cost?
#10 |
You can also use electric kettle elements. Typically about 2 2 Ohms, so is you wire 3 in parallel you get 7.3 Ohms.
Good for about 6KW when immersed in Water |
| Power load, dummy load (pic) | luka | Power Supplies | 43 | 9th February 2012 03:50 PM |
| 8 ohm dummy load | andrewe1 | Parts | 43 | 9th May 2011 06:44 AM |
| Tri Dummy Load | raudio1969 | Parts | 0 | 25th February 2009 02:14 AM |
| Dummy - load | JensRasmussen | Solid State | 24 | 23rd February 2007 02:04 PM |
| Resistors for dummy load? | wintermute | Solid State | 54 | 3rd February 2004 12:59 PM |
| Page generated in 0.09830 seconds (78.96% PHP - 21.04% MySQL) with 11 queries |
