Old 3rd March 2003, 08:02 AM   #11
All the motives for using silver bearing solder include either physical strength, higher melting point or environmental/safety issues. Supposedly, all Japanese manufacturers are switching to lead free solder, so if you think silver makes amps sound bad, you're out of luck because that's all you're going to see (or hear) in commercial amps in the near future.
***In accordance with forum policy, I must warn all of you that eating, drinking, touching lead and snorting solder smoke may cause birth defects, reproductive problems and just plain retardedness. If you believe silver joints sound better, you may have ingested substantial amounts of lead already. Do not use lead solder to cure headaches, spice up bland foods, or to floss your teeth, it's just bad mmmkay?***
Old 3rd March 2003, 11:08 AM   #12
Circlotron's Avatar
What sort of solder do they use inside a power semi package to solder the die onto the copper tab? If it's lead type then your stuck, arent you? Nyuk nyuk.
Old 3rd March 2003, 11:15 AM   #13
Circlotron's Avatar
Not recommended for diy dental filling repairs either.
Old 3rd March 2003, 11:49 AM   #14
dihydrogenmonoxide
LOL!
Old 3rd March 2003, 12:05 PM   #15
Circlotron's Avatar
Originally posted by sikkek
dihydrogenmonoxide
I saw on the news once someone actually fell into a large container of that stuff. It was fatal unfortunately.
Old 3rd March 2003, 12:37 PM   #16
Yes I know. I once was submerged in the stuff for about 1 minute. Makes breathing impossible.... Luckily a friend pulled me out, after which I could breath again. Nasty stuff indeed...
Old 3rd March 2003, 02:49 PM   #17
mrfeedback's Avatar
Default Not So Nice Colours And Pigments.
"so if you think silver makes amps sound bad, you're out of luck because that's all you're going to see (or hear) in commercial amps in the near future."
Yes as I understand it, that is a worldwide directive to reduce lead leaching into groundwater supplies from landfills comtaining equipment containing lead based solder.
The soloution is intended to be tin/silver solder, and in my experience this sounds quite fine, and it is lead/tin/silver solder that sounds bad.
"Do not use lead solder to cure headaches, spice up bland foods, or to floss your teeth, it's just bad mmmkay?***"
Watch out too for common and simple mistakes like drinking out of lead glass decanters, and using coffee cups etc using glazes or plastics containing toxic elements like lead and cadmium.
Eric.
I believe not to believe in any fixed belief system.
Old 3rd March 2003, 03:16 PM   #18
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Actually, lead crystal is perfectly okay. It's safely tied up as lead silicate.
BTW the real link is http://www.dhmo.org
Tim
Old 3rd March 2003, 11:41 PM   #19
mrfeedback's Avatar
Default Lead On The Rocks.
"Actually, lead crystal is perfectly okay. It's safely tied up as lead silicate."
Not so according to a New Scientist article years ago.
In the situation of whisky decanters, lead leaches out of the glass, and whisky drinkers using lead glass decanters were shown to have significantly higher lead blood levels.
Eric.
Old 4th March 2003, 12:23 AM   #20
Sch3mat1c's Avatar
Well I know I'm safe because I don't drink whiskey, much less do I drink it out of crystal, so there!
Tim
Lead Free Solder Recommendations and Procedures mhconley Construction Tips 7 19th June 2009 06:04 AM
3.5% silver solder sangram Everything Else 2 24th February 2006 09:29 AM
Lead free solder bigwill Equipment & Tools 11 12th May 2005 05:30 AM
Lead Free Solder Mike Gergen Parts 12 24th September 2004 04:41 PM
Lead free solder djmiddelkoop Parts 13 24th January 2004 05:52 PM
Copyright ©1999-2013 diyAudio
