Attached is the schematic fo the first audio amp I've ever designed. It was designed to output 180W into 8 ohms. It is a bit over-elegant incorporating:
1) a DC servo (not really needed, bt I want to experiment). 2) Optically isolated analog telemetry to a MCU based supervisor, controller, and SOA monitor on another board. 3) Complementary "Slone style" input stage and VAS. 4) Matched pair transistors. 5) Cascode current sources to get the highest open loop gain reasonable. 6) High open loop gain, with lots of feedback (I'm not a believer in the ultra-linear, low negative feedback approach) 7) Output relay contacts included in the feedback loop to maximize DF (again overkill). 8) Bipolar output stage using transistors with integral, thermally tracking bias diodes. 9) Switchable soft-clipping I design electronics (namely rad-hard PWM motor controllers) for space applications (Current and previous Mars missions and much more) so class D is more my forte.... And my amplifier doesn't use any 5962R... or JANSR components! Just kidding... The design attached simulates wonderfully in PSPICE. Now I'd like to see if it passes muster with the experts. I haven't built it yet, nor have I even started the PCB layout. I'm hoping to incorporate input from the group before I move on. Please let me know what you think. What I did right? What I did wrong? And most importantly, what did I do so wrong that will make it not work! Cheers! john |
#2 |
Hi
I honestly cannot work out how your VAS circuit can work. The voltages at the emitters (pin 5) of Q15 and Q29 seem to be fixed at ~+/-30.7V (disregarding the output stage bias string) Also, you must return the bases of Q20 and Q21 to ground via a resistor, especially of you intend to operate the amp with JP3 open. |
#3 |
Thanks for the quick feedback!
I agree with your assessment that the bases of Q20 and 21 need a DC path to ground. I had a resistor there but I must have deleted it by accident... I need to think about what you're saying about Q15 and Q29. My intent was another current mirror used to achieve translation rom the stages supplied by +/-30 to the stages that get +/-60V. In other words to mirror the current output from the input stage into the same current referenced to the +/-60V rail so I could use the Linear Systems transistors at the input (they won't take 60/120V) John |
#4 | |
Ok, but if you wan't to use a current mirror to perform such a task you need to take the output signal from the collector, not the emitter. Did you accidentally substitute some NPN's for the PNP's in the drawing? Another thing you need to be wary of is that Slone's published circuit with the complementary long tail pair inputs and current mirror loads is a furphy - it cannot possibly work due to the fact that the VAS standing current is not defined. Cheers, Glen |
#5 |
A few other things:
The temperature coefficient of the diodes in those Thermal Trak transistors differs from that of the B-E junctions by a significant degree. Maybe OK if you are willing to put up with a quiescent current that wanders a bit, biasing the output stage a bit on the hot side to compensate. Larger emitter resistors for the output transistors would likely be required. Check this thread out for ideas on compensating for the temperature coefficient difference: Biasing/thermal compensation of Thermal Trak transistors Also, WRT the unworkable Slone circuit, it’s inherent flaw has been discussed here in numerous threads (a quick search should pull a few significant links). For a circuit that allows current mirror loads to be used on complementary LTP inputs, see the schematic here: http://www.diyaudio.com/forums/showt...51#post1413451 Cheers, Glen |
#6 |
Hi Glen
Ive read some of your threads and seen some of your designs here, youre excellent with transistors. What is your take on the stochino vas?? Does it have "fighting vas" problems too ? Have you ever listened to this amp and if so what do you think of it? Alex |
#7 |
I just learnt people can have different definitions for elegance:
http://en.wikipedia.org/wiki/Elegance |
#8 |
Glen,
Thanks again for your input! I indeed transposed the NPN and PNP transistors in the VAS. My PSPICE simulation has them correct. I will research your concerns about the "furphy" Slone circuit. At this time, I need more understanding as to why it won't work, especially in my incarnation of the topology. When I have it all worked out, I will post a new schematic with the items in question repaired. BTW, I had to research the meaning of the word "furphy." I've never heard that word before! It doesn however, fit the bill! Cheers, John |
#9 |
Glen,
Can you repost http://users.picknowl.com.au/~glenk/CLASSA.gif ? I'd like to study how you made the complentary topology work... Thanks, John |
| An overkill power supply? | raveon | Solid State | 19 | 16th December 2009 01:04 PM |
| when does bass get to be overkill? | scottr0 | Subwoofers | 54 | 21st March 2007 06:51 PM |
| B+ TX. overkill? | Richard Ellis | Tubes / Valves | 2 | 26th September 2006 09:12 AM |
| 4x3886 chassis overkill | G4ME | Chip Amps | 5 | 8th August 2005 11:59 AM |
| Page generated in 0.11264 seconds (80.94% PHP - 19.06% MySQL) with 11 queries |
