Having been a reader for a fair while the forum has encouraged me to try building an amp again - the last one was a valve amp in the 60's
Having read the pass lab and solid state posts a Mosfet amp was in order from the parts bin (junk box) This is my attempt at a minimalist class A amplifier, 10 components per channel on veroboard. I'm surprised at its quality given the simplicity. Some notes, I run this at 9 volts though 8 to 25+ seem to work with variations in R2, Testing seem to show the mosfet matters little, various IRF and some odd switching mosfets out of bust PSU board work. Set the Bias current with VR2, at 9 volts on V+ 1 amp produces a good sound. set with an ammetre or measure accross R2. As its Class A a decent heat sink is needed, and an old CPU one worked well for me. Thanks to all the posters for reviving my interests in audio electronics, its been fun building this and I'd like to share the results. Alan |
#2 |
The one and only
Have you tried it without the diodes (and c2)?
#3 |
Nelson
I did try without diodes, Clipping distortion without the voltage lift from the diode junctions occured, I originally designed this with a resistor in place of the diodes but the power disappation was to much for the junk box why 9v (9.8 actually) is due to a scrap 8volt 4 amp toroid I had in the junk box. I read as many of your insights and thoughts on audio as I find, finding them inspirational, you are one of the reasons I have come back to real audo after a long break, Alan |
#4 |
Hi Nelson
The diodes give 1.2 v to the source of the FET. He needs the gate to be in lower voltage from the source, so he put the diodes (and the capoacitor filter ac changes). |
#5 | |
The IRF830 appears to be an enhancement mode device, not depletion. The Gate will need to be more positive than the Source. The load resistor (R2) is 2.5 Ohms. At 1A bias, that's going to give you a 2.5V drop. At that point, the amp will clip asymmetrically. You could increase the bias, but that would likely blow the MOSFET in short order, as it's only rated for 4.5A, or increase the value of the load resistor to the point where the Drain of the MOSFET settles somewhere close to half whatever rail voltage you choose. That will (within the limits of the MOSFET) give you better clipping performance. Assuming a 9V rail and 1A bias, a 4.7 Ohm resistor will come pretty close. Use at least a 10W resistor and ventilate it well. 20W would be better--you'd be less likely to scorch your fingers. Grey |
#6 | |
#7 |
thank you for all the observations, The parts used were what was to hand, designed the old fashioned way - scope and meter
.Grey, I will acquire a suitable pair of power resistors and play, maybe I can drop the diodes that way, without them I got asymetric distortion far to easily. The fun in building this and your comments have encouraged me to continue to see what it will do with a better set of components now on order. Currently its playing music from a FM tuner and has been doing the last few hours through a pair of fairly sensitive home brew speakers - even the better half agrees it sounds good. |
#8 | |
One of the first demonstrations they gave back when I took electronics in school was to run three identical value resistors in parallel across the output of a power supply. The only difference between the three was the wattage: 1/2W, 1W, and 2W. Since all three resistors had the same value and were in parallel, it was obvious that each was dissipating the same amount of heat. The difference in wattage rating, however, made it instantly clear why higher wattage resistors are bigger--the 1/2W was too hot to touch, the 1W was touchable, while the 2W was merely comfortably warm. Why? Surface area. The amount of heat radiated per unit of surface area decreased as the physical size of the body of the resistors increased. So, yeah, a 20W resistor will be cooler to the touch than an equivalent 10W resistor, assuming the same heat dissipation. Grey |
#9 | |
Let's focus on your example, so it is about a 4.7 ohm resistor under a 1A DC current. This would make a DC power dissipation of 4.7W, say roughly 5W. Take a look at this power resistor spec http://www.yageo.com/pdf/yageo/Leade...P_NSP_2008.pdf they are fairly standard ceramic body wirewound resistors, of 1W to 25W power. A 10W power resistor under a 5W load (50% nominal) will heat up in free air convection up to 125 centigrades. A 20W power resistor under 5W load (25% nominal) will heat up to 95 centigrades. 95 centigrades is certainly lower than 125 centigrades (btw, it is the convection that keeps the higher power device cooler, not radiation!) although I doubt you'll be able to keep your fingers on it. However, cased amps certainly cannot be considered as a "free air convection" environments. In a closed case (even if well ventilated) the temperature difference between the two resistor will certainly be much smaller. How small? Can't tell precisely, because it all depends on the case construction, but I wouldn't set hopes for more than 15-20 centigrades... In the extreme case of a complete sealed case (which is certainly not true for a power amplifier) the temperatures will be almost identical. Then the legitimate question arises, why and when should we use high(er) power resistors? The answer is reability. All devices (passive and actives as well) share the same type of failure rate vs. temperature dependency, and that's generally an exponential shaped curve. We certainly shouldn't use high(er) power resistors only to avoid finger burnings, we are anyway not supposed to touch those Interesting enough, the closer you get to the nominal power, the larger the temperature gap becomes. I would for example have no reserve in recommending for this application a 10W resistor over a 5W resistor, but certainly I could barely justify the cost and size of a 20W device over a 10W device. |
#10 | |
Having acquired a couple of 4.5 ohm 20 watt resistors - I too don't like scorched fingers - and clamped them to a small finned heatsink, dumped the diodes and set the bias to @ 5 volts. Actually best trimmed with a scope and a signwave the result is a bit better - quality the same but more headroom. If anyone builds this you need a clean power supply - eithor lots of capacitance or a regulator |
| Minimalist diy preamp project | Mywing | Pass Labs | 21 | 4th May 2007 01:24 PM |
| minimalist valve pre for follower | mikee55 | Tubes / Valves | 10 | 26th February 2006 10:31 PM |
| Minimalist DAC: is this possible? | beppe61 | Digital Source | 12 | 27th July 2005 09:08 AM |
| Minimalist A/B fet amplifier | plp | Solid State | 24 | 8th June 2003 11:58 PM |
| Page generated in 0.13410 seconds (85.13% PHP - 14.87% MySQL) with 11 queries |
