Like the clean layout and sound on 10year old 2 channel stereo receiver.
This receiver has a well known problem due to a transformer hum on some units and mine has that problem. When I turn on the volume more than 1/4 turn (only nice background sound level on my 90dB speaker), faint hum can be heard. As u can see the it has a clean layout (well kept for 10yrs), is there a easy way to "isolate" the transformer to rid of the hum?, would appreciate any help on how to mod this thing for this newbie. I know how to cut and solder wires but a beginner in diy electronics. if someone can point me to a web site for how to and perhaps parts that I may need. ![]() ![]() ![]() gychang |
#2 |
#3 |
Your humm is probly not the transformer, on older units the electrolytic capacitors start to dry up and become useless for filtering. I would try taking some 1000uF caps and tack them in parellel on the big caps and the regulator caps and see if it goes away.
#4 | |
So the question is gychang, is it an audible hum through the speakers and if so does the volume affect it or are we actually talking a hum from the transformer? This will lead us what to advise next. |
#5 | ||
I mentioned that because of what he said. |
#6 |
It does "sound" like he is referring to the hum emitting from the speakers so yup I'd try the filter cap tacking but I just like to be sure before going guns o' blazing. Not a whole lot under the hood is there
#7 | |
The hum is from the speakers, and it gets louder when I increase the volume, if it is the caps, could someone point out which one it is? (don't have a schematic though). Where can I get the part I need?. thanks to all for the suggestions. gychang |
#8 | |
#9 | |
your earlier post suggested these were 1000uF caps. 1. how do I "add one to it" (parallel) can I hot wire from the bottom and solder the new cap? 2. will this work? http://www.mcmelectronics.com/produc...me=MCMProducts thanks in advance. gychang |
#10 |
Well if your gonna be ordering the 1000µF cap just to tack in to try and check the filter caps and paying shipping etc. you might as well just buy the smaller sizes. You can use one of the new ones to tack and test. Afterwards just replace the smaller caps and be done with them. The 2 smaller side by side circled are 2200µF/35V and the single is a 1000µF/35V (they are cheap!) The 2 larger filter caps are 10000µF/63V and more costly.
| My beloved amp | ROCKMANDRAKE | Solid State | 174 | 20th September 2009 08:06 PM |
| Need suitable transformer for Nakamichi TA4A receiver | gto127 | Parts | 0 | 23rd January 2009 02:19 AM |
| Big transformer (pulled from Sony receiver) | maurycy | Swap Meet | 0 | 1st December 2008 01:29 PM |
| Transformer from Sony A/V Receiver - what's up with these windings? | Stephen Morgan | Solid State | 15 | 7th February 2007 05:11 AM |
| Page generated in 0.11097 seconds (81.73% PHP - 18.27% MySQL) with 11 queries |
