#21 |
Opamp in general;
I can say that the OPA627 doesn't fit to my music style (old and new guitar rock). The OPA134 is a good and cheap choice. However I must say, that I do use the old LF356 Opamp for my woofers
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com |
#22 |
Hi
While waiting for the PCBs, I´m designing the case. The output transistors are all sitting on the PCB and that´s somthing new for me. I come to wonder how it´s intended to be mounted, for best heatsink. Standing on the shortedge with the transistorhalfside upp and transistors pointing left and right would make best. It means a relatively short but high heatsink ? |
#23 |
Ragnwald;
If you use a proper heatsink and heat conduction paste, it doesn't matter if they are turned up/down or left/right
#24 |
I have updated the Quick Assembly Guide
Added more info on components, updated text in SOA protection, drawings with test points added, updated text in First test and added drawing for basic wiring.
#25 |
Could you give some general information on how much power (current) the board takes?
I mean if I want to get the specified 150W from 8 ohm - that calculates to 31.6 Vrms, 44.7V peak, 3.95 amps. So pure audio side needs 44.7x3.95=177 VA. How much do all the transistors take etc ... ofcourse one could go out and buy the largest transformer available but what are the specifications (with a little headroom) for an optimal transformer? From documentation 300 to 500W transformer is a little wide specification. Thanks, Olev |
#26 |
Thanks Jan
Hm... tell us about old LF356 Opamp |
#27 |
Jan,
Excellent assembly guide, it's better than any professional kit that I'd read. Please tell me how the lf356 sounds? I have some old ceramic base lf 356 and never use it also can I make some suggestipn ? Maybe you can add PSU bleeder resistor on your psu rgds, |
#28 |
olev;
Your calculation is right and a 200W toroid can do the job for one channel. However if you intend to play loud (which this amp is build to) you may get into problems keeping the Capacitor Bank fully charged. That's why many (my self included) recommend to use a toroid that is at least 1.5 times bigger than nominel output Wattage. I will put something in the assembly guide Ragnwald and dexter; Just one of the most used opamps in the old days I think it's exelent for rock music, however I will not recommend it for more delicate classic music. It's still easy to get and it's cheap. Use a 8-pin DIL socket on the pcb, and make your own listening test
#29 |
ACD; Do that mean you nead toroids of 600VA pr. channel to get reliable 400W output pr. channel into 2 Ohms ?
Going for supply voltage of +/- 55 Volt DC, as in your exampel. regards |
#30 |
Ragnwald;
If you are going to use such low impedance speakers, you don't need +/-55 VDC. You can achieve 400W/2 Ohm with +/-43 VDC Rail Voltages. But yes I would recommend a 600W toroid with 2.000uF per Rail per Ampere.
| Page generated in 0.14913 seconds (63.43% PHP - 36.57% MySQL) with 11 queries |
