Hello
I've got a pair of old 8ohms speakers I've been asked to turn into self-powered speakers. It's for a small room and on a very tight budget. I've got at hand a 10-0-10VAC/2A transformer. This should be good for around 2X8W, which is more than enough considering the size of the room and the efficiency of the speakers. So my questions are: - is the attached schematic correct ? It's obviously inspired heavily by the P3A from Rod Elliot. - can I use BC550C/560C for everything but the output transistors (which won't be heavily biased, sound quality is of secondary concern) ? - are the bd241c-242c good enough for my purpose ? Thanks in advance.
Ben. |
#2 |
Should work, but even simpler would be an opamp-follower type amp. Take a look at P76 or even P113 for example.
#3 |
R7 and R8 should be 10k or less.
#4 |
sawreyrw: r7 and r8 are 1500 ohms, which is less than 10K. Do you mean 1500R is too low ?
Ben. |
#5 |
add emitter resistors to Q1, Q2 & Q4. Increase R5 to 3k9 and be prepared to trim it slightly lower to balance the currents in the two halves of the LTP. Add a resistor above the Vbe pot and take the base of Q8 to the bottom of this extra resistor. Allow for a Zobel on the output. C2 could be lowered down to 33uF without loosing any more bass or alternatively increase C1 to 3u3F to extend the bass response. I am a bit doubtful about using bc550s for the drivers.
regards Andrew T. |
#6 |
20V-CT transformer + tight budget > let's build a chip amp, TDA2030 or similar!
#7 |
First of all, thanks to everyone:
While it would have been more interesting to build a P3a-like, I think Andy is right. It's going to be a bit faster and probably more reliable to build an amp based on a pair of tda2030. The discrete amp would have cost 1€ more per channel and be like two cm wider and longer.... not something I would worry about.
Ben. |
| Wow! 100VDC rails | whatsnext | Solid State | 82 | 5th November 2006 06:54 AM |
| from +/-80v to +/-70v rails | leander | Solid State | 14 | 13th September 2005 11:26 AM |
| filament rails | resident | Tubes / Valves | 2 | 22nd October 2004 12:48 PM |
| Cap across rails? | MikeW | Pass Labs | 12 | 24th August 2004 01:35 PM |
| (+)(G)(-) rails from a floating (+)(-) PS? | 2004ex | Solid State | 4 | 21st June 2004 05:14 AM |
| Page generated in 0.08731 seconds (77.45% PHP - 22.55% MySQL) with 11 queries |
