Hi
my last project is an hybrid with 2SA1215 and 2SC2922 drived from a copule of comlementary hexfets IRFP240/9240 (after evaluation will be IRFD110 & C) the output is with big capacitors (20.000uF) just to leave DC (this balanced solution don't create emphasys on music) in this particular design i have put two bipolar devices instead single one (in AB bias) because need Class A sound without bridge there is an "auto-biasing" between a copule of complementary transistor in this configuration, so need just a resistor base to base |
#2 |
I don't understand the schematic, is that really working circuit?
#3 | |
Hi, I can guess how it works ![]() but could you send exact schematic?
regards, Pawel |
#4 |
I don't know if works
is a project until this WE this double bipolar ( renamed Tripolar ) is a PNP+NPN with common collector so is like a self-biasing device that works (may be) in phase as a variable resistor ( signal modulate value ) input satage with common source split phase in two opposite rail without feedback and mirror Regards |
#5 |
more details please .....
looks so simple ....very symetric ...i like that how much power ????? how stable ????
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#6 |
So you are trying to foce transistors both the same collector current and base current. I don't think it is workable, you'd need identical beta...
#7 |
this have seen on QUAD RIAA amplifier
just one pair with capacitors output... may be works when I find drawing can attach for you see soon |
#8 |
This looks like a power logic gate
Bear in mind that every transistor has unique parameters, which are temperature dependent too. Some kind of feedback is requited to keep biasing stable on all stages.
I use to feel like the small child in The Emperor's New Clothes tale |
#9 |
#10 |
Notice that in the schematic you linked in your last post there is no capacitor in series with bjt's bases, so no need for identical beta. Compare this with your circuit...
| Peavey "Super Festival" VTA-400 - upgrading to 400W? | pharaohamps | Tubes / Valves | 11 | 22nd March 2009 01:25 PM |
| "More stuff" final clearance sale. | Colescuttle | Swap Meet | 6 | 5th January 2007 03:29 PM |
| Some final pics of "Stacks" revisited and "Askew" with stand | Andy G | Multi-Way | 2 | 3rd February 2005 07:07 AM |
| Audio Crafters Guild "Super Symmetric Power Supply" | raincheck | Digital Source | 16 | 22nd April 2002 09:06 AM |
| DIY "Final Scratch" Turntable DSP | Ignite | Digital Source | 5 | 26th February 2002 12:52 AM |
| Page generated in 7.29320 seconds (2.18% PHP - 97.82% MySQL) with 11 queries |
