Hi, I got this soft switch from a friend and since I needed three for my system I put them together. The problem is that they bounce something terrible. My undeducated guess is that the NE555 sences the pulse from the switch and then "tells" the transistor to activate the relay. The bouncing is due to the fact that the little chip reacts to every litte disturbance it comes across and the solution is to make the NE555 ignore shorter pulses and just react to some more firm ones.
So, am I right and if so, how do I do it? The circuit I used is attached and I hope that it is OK to post it. Since I don't know where it came from I can't ask.
.....Where the music comes to die. |
#2 |
Try this, work 1000%.
Regards zeoN_Rider |
#4 |
CD4014 is 8-bit static shift register.
#6 |
oh, thats right. My mistake
4013 it is
#7 |
I, don't know what he meant.
#8 |
That is better!
#9 |
Check out this simple latch circuit. It will insure a perfectly debounced state on the output at all times. Any metastate due to switch bounce will leave the output in its last state. Follow the logic and you will see.
Nihilism is best done by professionals. |
| Soft switch version 2 anyone? | Maxhawk | Group Buys | 87 | 15th September 2010 08:39 PM |
| Soft start + switch on PCB | smithy666 | Solid State | 29 | 4th September 2007 05:33 AM |
| Soft start & Soft Switch circuit: can anybody help? | m.parigi | Solid State | 95 | 22nd August 2005 03:32 PM |
| Page generated in 0.09220 seconds (77.02% PHP - 22.98% MySQL) with 11 queries |
