Output stage opinions
Old 18th February 2008, 06:42 AM   #1
CBS240 is offline CBS240  United States
CBS240's Avatar
Question Output stage opinions
Hi
Recently I have successfully used an output circuit similar to Mr. Cordell's Hex-Fet EC output stage. I have made some modifications, on paper, to my circuit that I think may work better. The VAS is biasing the +/-11V DC and provides up to +/-22V signal swing (up to 33V) max, adequate for clipping.
My thoughts are to use higher frequency, small signal transistors to increase the bandwidth of the error correction amplifiers. Also, I added a cascode for the first pre-driver and last driver transistors so as to have a constant Vce, and to be able to use small signal, low noise, fast devices for these and still be well within their SOA. The output fets have a Vgs threshold of about 3.5V. The two Vgs multiplier transistors (SOT-23) could be mounted so as to be in contact with the drain lead of the output transistors to sense die temperature. Something like this example
I am thinking it should work well, but I thought I might try to get a second (or more) opinion. Is there any reason this wouldn't work?
The transistors I plan to use are:
KSC2223
MMBTH81
FJV1845
KSC1845
KSA992
FJV992
BC850
BC860
and these 'space savers' from On-Semi, labeled 1/2 and 2/2.:
EMX1DXV6T1-D
EMT1DXV6T1-D
All the trouble I've ever been in started out as fun......
Old 18th February 2008, 08:21 AM   #2
CBS240's Avatar
Or is this circuit better?
The difference is where the base bias for the Vbe multiplier comes from....
Old 18th February 2008, 05:40 PM   #3
myhrrhleine is offline myhrrhleine  Belize
myhrrhleine's Avatar
Mr Cordell is on this forum.
You could PM him directly.
Also, he recenty posted, the faster the xistors, the better.
See his ongoing discussion on EC.
http://www.diyaudio.com/forums/showt...threadid=89023
[Grasshopper]:Old man, how is it that you hear these things?
[master]:Young man, how is it that you do not?
Old 18th February 2008, 08:53 PM   #4
AKSA is offline AKSA  Australia
Myhrrhleine,
Is that really you in the avatar, looking remarkably Basinger on the sofa?
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 18th February 2008, 09:14 PM   #5
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Man... i have almost fell down from my chair watching this avatar
My God!
Beautifull!
The problem is that if you go to check..ahahahah..will find a seven foot high male with a big moustache asking you if you wanna a kiss.
ahahahahaha!
I do not want!
regards,
Carlos
Restriction removed ; ttps://www.youtube.com/watch?v=3ioyOjAzDt0; https://www.youtube.com/watch?v=uFcnddpe3MU
Output stage opinionsHide this!Advertise here!
New gain stage .. Opinions??? nitrate Tubes / Valves 4 26th January 2009 01:02 PM
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 10:18 AM
Output stage biasing, with the driver stage andrew_whitham Tubes / Valves 0 19th May 2007 11:14 AM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 06:15 PM
Curcio Sarah Phono stage: opinions? ad010685 Tubes / Valves 4 8th August 2006 12:30 PM
