#11 |
Is a DC servo (all NPN of course) allowed or does that count as AC coupling?
#12 |
Much talk but no schematic yet
Cheers// Ove |
#13 |
sorry, was thinking output stage only. My bad.
-SL |
#14 |
I see no problem with a dc servo ! Anything other than complimentary devices in this case I have said NPN only
The amplifier can have a input capacitor and a feedback to gnd capacitor the spk is to be dc coupled to the output stage I have as yet no schematic of my own the idea is to get away from what are esentlialy only variants on standard schematics! level translation could be via diodes ,zeners/opto devices capacitor or even galvanic Just no pnp devices regards Trev |
#15 |
Whoop, this is the result of ten minutes. The output stage could be drastically improved and scaled for a typical load, but that's the easy part, this is just an example topology.
Around 40db open loop DC gain climbing to 80 some db, currently uncompensated and marginally stable with a 260mhz gbw. |
#16 | |
![]() se |
#17 |
Tim X I can not open your attachment all I get is a wiring list ?
please give us a diagram !!! The other one by steve eddy is interesting ! and very unexpected lots of iron though! still its food for thought I shall submitt my concept sketch tonight regards Trev |
#18 |
This OP stage is mostly NPN !!
The inner diff pair / current source can be readily replace with NPN but this leaves a level shifting problem - maybe a current sourced NPN E-F and a resistor to shift the level ? |
#19 |
It was an LT Spice simulation file, earlier I wasn't on a computer with image editing software installed.
Obviously I ignored the power goal, and only focused on making a workable topology with only NPN devices, I chose to go DC coupled throughout including the input. The two caps in the second stage serve only to enhance AC gain, there is still considerable DC gain and complete control of the output stage down to DC. |
#20 |
I should note: it's VERY unpolished, it is just a work of ten minutes and ONLY an example of topology, not a fleshed out buildable schematic. DON'T build it as is..
| The under $100 challenge | cotdt | Multi-Way | 60 | 13th March 2006 06:11 PM |
| a challenge --or I need help | lawrence99 | Car Audio | 0 | 9th March 2005 04:44 AM |
| The 55 Litres challenge !!! | richardkrol | Subwoofers | 7 | 10th March 2004 11:21 PM |
| The challenge ! | thylantyr | Solid State | 51 | 24th July 2003 08:41 PM |
