Negative feedback?
Negative feedback?
Old 14th March 2003, 02:58 AM   #31
Solid Snake is offline Solid Snake  United States
Wouldn't putting a resistor in series with the speaker produce a current feedback effect? Would this cause uneven output near a speaker's resonance?
Old 14th March 2003, 03:10 AM   #32
Tube_Dude is offline Tube_Dude  Portugal
Tube_Dude's Avatar
Default Feedback of current...
If you put a resistor betwen the - of the loudspeaker and ground...say 1 Ohm and take the feedback from the union of this resistor and the minus of the loudspeaker...
Yes you have a current amplifier...aka a current source!
Yes ...because there be no damping at all...
regards
Jorge
Old 14th March 2003, 04:35 AM   #33
What if instead of a small value resistor between speaker - and ground, I feed back the speaker + through a high value resistor? That would be voltage feedback right?
Old 14th March 2003, 01:29 PM   #34
Tube_Dude's Avatar
Default Voltage or current...
Right!
Jorge
Negative feedback?Hide this!Advertise here!
Negative Feedback? Binaural Tubes / Valves 15 12th March 2009 07:05 PM
Negative Feedback AmpBuilder225 Tubes / Valves 7 20th February 2009 08:05 PM
Less Negative Feedback Is Better? CarlosT Chip Amps 25 14th December 2006 10:18 PM
Negative Feedback Jack Thomas Tubes / Valves 6 5th May 2003 12:38 AM
