Hi!
I wish to by a 390s from the States, problem: the voltege, does anybody how to make it work at V220? with power amp like 332 or 336 is quite easy! Please help me Thanks Regards Adriano |
#2 |
Basically, all Levinson equipment uses jumpers to set transformer primaries which are compatible with all voltages (visible on left in a picture). However, some of the equipment has also circuitry that monitors mains frequency (a chip on the right in a picture of ML390S).
In such case, even if you set primaries properly, you will get diplay message WRONG AC with a code. Apparently, when you contact Madrigal and give them that code, they will provide you with a new code which when entered through the remote will set the microchip allowing the equipment to operate with a new mains frequency (50Hz vs. 60Hz)
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#3 |
Hi!
thanks for fast replay, I have a 320s and, and this is what I done to make it work at 50Hz is a small board witch generates the frequency, see link. Adriano http://img176.imageshack.us/img176/9043/pict0530al2.jpg |
#4 |
Yes, that will work too
#5 |
Hi Adriano,
I noticed that the numbers are filed off the transistors / ICs. Since this looks like an interesting project, would you be willing to detail your circuit to our members? -Chris
"Just because you can, doesn't mean you should" © my Wife |
#6 |
Sorry i'm not the one who made it, I'm just the 320s owner!! I wish I knew those numbers!! i just can tell you that is something witch give the 60Hz so you do not need a new code
Adriano |
#7 |
It was a gamble but I've bought a ML390s in the US and did the conversion myself. There was no password code and it was as simple (for someone who studied older electronics, like my father) as moving a jumper to the correct position.
If you look closely at the following picture: http://www.marklevinson.com/image_library/390SOH.jpg you'll see a white jumper block (8 positions) with copper jumpers. On the picture the jumpers are currently set at 110v (starting from the top that's (2/3 and 5/6)) and should measure something like 27 ohm between line and neutral (that's where the voltage cable goes in). For 220v there only needs to be one jumper between 4 and 5 and this should measure around 98 ohm. For the 240v configuration one jumper should be set to 1 and 2 and should measure 109 ohm. Cheers, Alexander |
#8 |
Hi!
Is it so simple? what about frequency? 60 to 50Hz end viceversa? Bebo |
#9 |
Hi Bebo,
Yes that simple. I really thought (reading all the stories) there was going to be a 50/60hz check. I even prepared for this and bought a Willem eprom programmer to start hacking (it's a AT29C010A 128k flash). But to my big surprise there wasn't. And it sounds great Cheers, Alexander |
#10 |
hello, someone can give an help? I purchased an used preamp Mark Levinson 320s from a seller in U.S.A.. I live in Italy . I received the package this morning from ups and before to turn on I set the preamplifer to 230 / 240 volts ( here in Italy the voltage is 230 /240 ).
When I turned on the preamplifier, it asked me a key of 5 numbers or I can't use it !!! I don't know that code. What do you think I can do? Thanks for your help, Andrea |
| '70s Mark Levinson Op-amp | thermionic | Solid State | 5 | 5th November 2008 07:18 PM |
| Mark Levinson ML3 | minorl | Solid State | 0 | 6th July 2004 04:59 PM |
| mark levinson | karma | Swap Meet | 8 | 8th March 2003 01:42 AM |
| Mark Levinson ML2 | arnach | Solid State | 7 | 9th April 2001 04:36 PM |
| Page generated in 0.10005 seconds (77.93% PHP - 22.07% MySQL) with 11 queries |
