#21 |
Hi all
I don't know if it is necessary for a mercury relay, unless you want to really test very short pulses? Most SOA curves follow "DC" or 1 S tests then increase in dissipation for 1 mS... I think that a transistor timer stage should be enough for pulse durations to 10uS or less if high speed circuit design is used. And since the curent source transistors might take 1 uS to turn on maybe SOA to 10 uS is enough. From what I have heard about fakes it seems to me that DC or 1S testing will determine how good they are ... as long as the crowbar turns the TUT off when it fails ... cheers John |
#22 |
This would be a very useful tool on any DIY bench... any progress here?
#23 |
another SOA tester paper from Motorola
http://www.datasheetarchive.com/pdf/685820.pdf I think now the test time of SOA tester is 1mS, 100ms,1S....not less than 100ns. |
#24 |
All sounds pretty good to me
I think the idea of setting up these tests first with minamul equipment, evaluate the results, determine what will be necessary with a compresive set of prototype circuits and set ups, before building it I test devices with BVds up to 30V and Id cont. to 60A. That sounds easy |
#25 |
Has this thread moved elsewhere ?
Most links on page 1 says 'access denied' . So has anyone designed or tested anything yet ? Cheers.
AM |
#26 |
Hi Ashok,
I will try to get back to this tread. Interest has been shifted away from designing and building testgear to repair of musical instrument amplifiers. There hasn't been much time to build any thing. Ideas enough but hands and time to short. And the community is in need of a helping hand; so that's me then... Cheers, Tarzan |
#27 |
Hi Tarzan,
Great to get see a reply ! Maybe the work load could be shared ? Test out verious sections if required . Just to get the design tested and working as soon as possible. Your hands seem full right now. How's Jane ?
AM |
| Speaker measurements in the SF Bay Area | neil_kaye | Multi-Way | 1 | 21st May 2008 04:20 PM |
| safe operating area | TroelsM | Solid State | 39 | 23rd January 2005 08:19 PM |
| Page generated in 0.09134 seconds (75.59% PHP - 24.41% MySQL) with 11 queries |
