I'm building a pair of monoblocks using my trashed DH-220
and DH-200 and MC's Signature cards. I installed MC's GX mods in the late 80s in these amps, but only 1 of the 4 total channels work(ed). My electronics knowledge is fair to poor, so I have some questions and thought I'd briefly share the project's progress. (I'm a smidge better at fabrication than electronics) So far I've completed the power supply section in one block. A few photos. ... This is the filthy GX modded 220 before major surgery. I'm retaining the stock xfmr, mosfets, sinks, chassis, and LC-200 filter caps I installed a few years ago. |
#2 |
Here the amp has been gutted, cleaned, and new wiring and components installed.
Those are Ixys, 12 amp, 600 piv diodes. No heatsinks. I decided to make small copper buses to make sure the bypass caps and resistor will fit under the cover. It is possible using multiple regular lugs, but I thought this was a better approach. I thought about using toroid power xfmrs; but reading this forum convinced me to stay with the stock units. I may replace the stock binding posts and install a soft start circuit. The V - shaped addition to the star ground wire, connected to the CT, is specified by Musical Concepts. Something about isolating Charging gradients. I'll have to study up on that one. |
#3 |
Just a close up. I spent a lot of time coming up this
and there's probably a better way. I'm trying to minimize potential oscillation problems, though such concerns may be unwarranted. The heavy internal wiring is 16# Carol (supplied with kit) and 16# pulled from a Lowes extension cord. I thought of using heavier, but think -- hope -- this wire is ok. That's the extent of my work thus far. Now I must tend to installing the new PCBs, new (used) Mosfets, then final assembly. I have a variac, scope, and sig generator. I'm not crazy about the condition of the old mosfet sockets: some warping and HS compound pollution. I can Probably fix them but wonder if I should replace or solder wires directly to the pins? I assume fresh Radio Shack heat sink compound is sufficient? That's it for now. Thanks for looking. I've been reading DIY for years. Wink |
#4 |
The first monoblock finished. It seems to be working fine. Biased at 330 ma. I can't really tell how it sounds yet -- only one channel and not broken in. John Hillig says break-in takes about a month.
I am a bit concerned about the square wave performance. |
#5 |
I'm in the middle of mastering the interpretion of square wave results, but this is with an 8 ohm resistive load at 10 kHz, .5V/cm. Wish it were a little more squared off.
#6 |
The result with a 2.2 ufd paralled with the 8 ohm load.
Not sure what to make of it. Overshoot and ringing obviously. I'm reading this threads such as: "Square wave testing....Cap value" and others in an effort to learn proper test methods. |
#7 |
The scope is an old tube Tektronics RM-15 (rack mount 515, 15 mHz) I found NOS at an Army surplus store, and function generator a Tenma 72-380.
I did look at the output of the Tenma directly connected to the scope and it looks perfect. Now on to building #2 monoblock! |
#8 | |
However, the stock DH-200/220 has normally a very good response with that load (ringing is not very high and is damped quickly).... Also ,when you do the test ensure to have short cable from amp to the load and good connection too... |
#9 | |
This scope has magnification capability, pix of which I didn't think to include. I will post much higher rez photos tomorrow. The load is inserted directly into the amps binding posts and cable to scope is ~ 2' long. My "resistive" load is a bunch of paralleled 1/2 w, 10 ohm carbon resistors. Regarding stock 220/200s -- of course the Musical Concepts pa-3d card is a vast departure from the original PC-19 driver card. I've been looking at square wave tests of highly regarded tube amps at Stereophile's site. Interesting. Thanks for your response. Wink |
#10 |
Hi wink,
I'm seriously concerned about your resistive load. You mentioned on one hand an 8 Ohm load but in your last post I could read on the other hand you paralleled a "bunch" of 10 Ohm(!) resistors. Well, if you parallel just two of them it would result in 5 Ohm, 4 of them in 2.5 Ohm, etc. Be honest - how many have you really paralleled? My advice would be to get somewhere resistors with a (much) higher power rating and a value that can be paralleled with much more ease to reach values like 4 and/or 8 Ohm. I'm for instance using 39 Ohm 10 Watt resistors and parallel 10 of them. Inclusively all soldering joints, cable and contact resistance I come up with a value very close to 4 Ohm. A more precise value would be 9x 39 Ohm + 1x 47 Ohm = 3.97 Ohm. The missing 30 Milliohm will be better accomplished by cable/connector resistance than in my case where round about 100 Milliohm needs to be added. But - what the heck - a little "overload" won't hurt that much |
| Hi from a new Kid on the Block. | Valvepower | Introductions | 1 | 26th January 2009 05:00 PM |
| New Kid on the Block | mrclassicman | Introductions | 3 | 10th May 2006 03:28 PM |
| New Kid on the Block... | LesPaulStandard | Introductions | 4 | 31st March 2006 07:37 PM |
| New kid on the block | Jrisk | Introductions | 3 | 26th February 2006 07:56 PM |
| Big Block S10 | BAM | Multi-Way | 6 | 14th September 2003 04:50 AM |
| Page generated in 0.12992 seconds (82.74% PHP - 17.26% MySQL) with 11 queries |
